oil leak from around harmonic balancer
Old Apr 5, 2008 | 12:24 PM
brent brum's Avatar
brent brum
Cruising
Default oil leak from around harmonic balancer
i have had my 2003 z06 for 2 years and 18k miles now. currently at 90k miles and is my d/d. two weeks ago at a hpde after the third 20 minute session i noticed the oil leak . i think i lost about 3/4 of a quart according to the dip stick. h/b now with slight wobble. since then i have had to drive to work (5 miles) never exceeding 2000 rpms and the leak has stopped. do you think it is just the seal arround the h/b or is the front crank bearing or seal bad. my plans are h/c, u/d pulley, arh headers with cats, tex clutch. if the front of the crank is bad i will possibly go forged. any help will be appreciated. thanks in advance!
Old Apr 5, 2008 | 09:18 PM
LinearX's Avatar
LinearX
My guess would be that it's the seal on the timing cover that the balance slides into.
Old Apr 5, 2008 | 09:22 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you're planning a cam install, then you will have easy access to the front seal then. The seal is pressed into the timing chain cover, and seals on the shoulder of the balancer.
It is a normal PM item to replace when doing a cam swap.
Old Apr 5, 2008 | 09:25 PM
der451b's Avatar
der451b
I think H/B with slight wobble is need to be replace first, if the seal is bad then need to replace too. Soon or latter your vette engine will exceed 2000rpm , H/ B wobble is bad , engine tend to more vibration .
Old Apr 6, 2008 | 07:46 PM
brent brum's Avatar
brent brum
Cruising
thanks everyone there is always nice people willing to share their knowledge
Old Apr 7, 2008 | 03:48 PM
FKING1's Avatar
FKING1
Mine started to leak when the balancer bolt came loose and the HB worked its way forward about 1/2". Had to have a new balancer and seal installed.
Old Apr 8, 2008 | 10:12 AM
brent brum's Avatar
brent brum
Cruising
i have checked the bolt and it is tight. hopefully it is just the balancer and seal. now i just have to decide between n/a or f/i so many choices so many variables. have a great day!
Old Apr 8, 2008 | 10:16 AM
Rhode Warrior's Avatar
Rhode Warrior
If you replace the balancer and have the car torn down that far, by all means replace the seal and timing cover gasket.
Old Apr 8, 2008 | 10:23 AM
brent brum's Avatar
brent brum
Cruising
and i plan to replace oil pump with a melling,and upgrade timing chain with comp cam chain.
Old Apr 8, 2008 | 12:52 PM
phalanx256's Avatar
phalanx256
Had the H/B replaced on mine. Make sure to use a new bolt to hold it on, and you have to torque it to 200 Ft/Lbs. Any less and you run the risk of it coming loose in the future (which happened to me because of unsaavy dealership mechs)
Old Apr 8, 2008 | 09:08 PM
brent brum's Avatar
brent brum
Cruising
stupid question, but is loctite ever used for this bolt? if so red or blue?
Old Apr 8, 2008 | 09:20 PM
Rhode Warrior
Red. Although if I remember correctly, it came with some threadlocker already on it.
Old Apr 8, 2008 | 09:34 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Originally Posted by Rhode Warrior
If you replace the balancer and have the car torn down that far, by all means replace the oil pump, timing chain, and camshaft!.
Fixed!
To oil leak from around harmonic balancer
