I had some time today and decided to clean the air filter. I was in disbelief when I opened it The air box was empty. I have 5K miles since I purchased the vehicle. Where can I purchase a Filter?
Call or go to the Vararam website. They will help you out with a filter.
Cannot believe there was no filter in there. What does the throttle bdy look like?
Yikes! Depending on what roads and the conditions you drove in I wouldnt worry about it too much. Unless you drove in sandy / salty / crappy conditions just throw a filter on her and change the oil you'll be good to go
Call me at 866-507-2648 and I can help you!!!
Steve
Did you buy the VARARAM new or used? Was the VARARAM on the car when you purchased it (used)?
I'd have concerns just as you do...
If the car was driven like this, you have big issue's that cannot be easily fixed. I would recommend taking an oil sample and sending to Dyson Analysis. Terry will make recommendations to get the engine back on track to the acceptable wear range.
I had a similar issue where my CAI filter was leaking because of installation error and I would not have found the issue unless I used oil analysis. It took a good amount of time to sort out the issue, but it's okay now.
