steam or pressure blast it clean then get under there and locate the source. Look at the oil pressure sender and I heard there is a plug for the location that a distributor would go had they used one.
Whatever you do, fix that leak before you run the car. The result of not fixing it is a nice barbecue fire. I guy's '91 here where I live went up in flames thanks to a oil leak that he didn't get to right away.
