rear end width questions
Old Apr 6, 2008 | 02:39 PM
CadVetteStang's Avatar
CadVetteStang
Default rear end width questions
How wide is the C5 rear suspension from wheel mounting surface to wheel mounting surface? Please specify if that is with or without the thickness of the rotors included.
How wide is it from the outermost part of the tire mounted on a Z06 wheel across to the outermost part the other rear tire?
Does a C6 wheel mounted on a C5 rear suspension narrow the overall width? If so, by how much?
Where do you get 18 X 12” wheels or 20 X 12” rear wheels and what is the cheapest way to do it? As in, if you already have Z06 wheels can you get two wider rear wheels that match the fronts?
Thanks,
Cody
Old Apr 6, 2008 | 04:10 PM
DeeGee's Avatar
DeeGee
Don't know if this helps:
