this is disturbing
Old Dec 12, 2001 | 11:17 AM
joe2gaan's Avatar
joe2gaan
Default this is disturbing
i read where changing the rev limiter will void your waranty. well doesn't that take all the fun out of driving. any thoughts? :U
Old Dec 12, 2001 | 11:29 AM
MitchAlsup's Avatar
MitchAlsup
Default Re: this is disturbing (joe2gaan)
We'll what would you do if you were GM with the following senario:
If we keep the RPM Red-lime at (pick an RPM) we will see only 13 failures this year from (our barely tollerable) materials and our (pretty tollerable) assembly methods. But if we increase the Red line by 100 RPM that 13 engines goes to 50 engines, at 200 RPM goes to 200 engines, at 300 RPM goes to 500 engines lost, and at 400 RPM we might loose 1000 engines. Every engine represents a customer with dissapointments, unnecessary stress, and a potential to loose this customer for the rest of his/her buying career.
Well what would you do if you were GM?
{The numbers are made up--but the potential is real!}
Old Dec 12, 2001 | 11:52 AM
jschindler's Avatar
jschindler
Anyone care to comment on this possible scenario. The GM dealer plugs in his diagnostic machine that is the only way he is really going to find out how many RPM's the engine has turned, or what the red line is actually set for.
Does his machine re-program your module back to stock settings at the same time?
Old Dec 12, 2001 | 10:30 PM
C5XTASY's Avatar
C5XTASY
I would have one question on this. I have read on the forum that Powerloader programming is not able to be detected by the dealer. I have seen supposed quotes from Steve on this issue. I believe the Powerloader resets the rev limiter to 6400 rpm from the stock 6200 rpm. How could the Powerloader reset not be detected and something like the Hypertech found out? Does anyone know? Does the PCM record the highest rpm setting and lock it in history? Or, if one resets the rev limiter to the original setting, can the dealer still see that it was changed, even if it wasn't "bumped" against?
Ed
Old Dec 13, 2001 | 01:57 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: this is disturbing (C5XTASY)
I think the bottom line is that your taking a risk. A lot of techs probably won't know, but you may get one that does. I'm not surprised this voids the GM warranty.
Old Dec 13, 2001 | 02:13 PM
oceanaire's Avatar
oceanaire
Warranty, Schmarranty, Just go for it. My dealer sucks for warranty work anyway.
Old Dec 13, 2001 | 02:46 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: this is disturbing (oceanaire)
Maybe so, but it takes away ANY legal recourse you have..............and MOST of us are not steenken' **** rich..........I NEED my warranty......if for nothing else than a leg to stand on, IF a big issue arises......
And judging from the posts i have seen in the 3 months I have owned my Z, I can easily see a reason to keep my warranty.....as P poor as it may be......
Removal of a fart stain from a seat cost $112,000.00................ :jester
Old Dec 13, 2001 | 05:09 PM
NeedSpeed's Avatar
NeedSpeed
Dealers can only re-program PCM's, not look in them. A service tech at best will update the PCM with the latest software from GM.
The only way they can tell is if they push the engine to redline and note what RPM it stopped at. Then they may wonder . . .
Old Dec 13, 2001 | 06:59 PM
C5XTASY's Avatar
C5XTASY
Default Re: this is disturbing (ZO6LS6)
I also can see the reason for engine warranty voiding if the rev limiter is reset and the stock limiter setting exceeded. However I really don't believe a 100-200 rpm bump will do anything. I believe that if it did, you'd see alot of posting from Powerloader owners about screwing up their engine. Personally, I haven't seen even one of those.
I sure would like to see a post here from someone who actually knows for sure, by experience (a tech?), that GM cannot tell if that rev limiter has been reset and then returned to stock. Anyone?
Ed
Old Dec 13, 2001 | 07:03 PM
C5XTASY's Avatar
C5XTASY
Default Re: this is disturbing (Buckmaster)
Don't tell them! Can they find out? Yes, but most Chevy techs will not know to look at this nor do they even know what the rev limiter is set at!
I forgot to add...how do you know "they can find out"? Is this belief based on fact or opinion? What do you mean "they will not know how to look at this"? I don't understand...:confused: This would be great if true. I just would like to see a basis in fact so I would know for sure. :yesnod:
Ed
[Modified by C5XTASY, 5:09 PM 12/13/2001]
Old Dec 13, 2001 | 09:04 PM
Mike Mercury's Avatar
Mike Mercury
I thought the GM TechTool II could download the cars current config...
which one is it?
Old Dec 13, 2001 | 10:01 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: this is disturbing (Mike Mercury)
Mike, Lou G......of LGM Motorsports, posted on here a few weeksback, about being DENIED warranty work, on an engine because of "RPM"s MAX Exceeded".........this was supposedly downloaded off of an onboard system.
If I remember correctly, RAT was in on this convo.....maybe he or Lou will chime in..........
There is incorporated into these unit's a feature called "Abuse Management System", do not know if it is part of the PCM, or a different piece altogether.........maybe kewlbrz, or a teched will let us in on the poop................... :yesnod:
Old Dec 13, 2001 | 10:05 PM
geekracer's Avatar
geekracer
Wouldn't that be the actual maximum RPM measured instead of the max RPM limit?
Old Dec 13, 2001 | 10:18 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: this is disturbing (NeedSpeed)
NeedSpeed is correct :yesnod: We cant change it,and there is only one way for us to check what it is set at ;)
[Modified by C-5 TECH, 9:20 PM 12/13/2001]
Old Dec 13, 2001 | 10:28 PM
C5XTASY's Avatar
C5XTASY
Default Re: this is disturbing (C-5 TECH)
Thank you! The man I was hoping would enter the conversation and confirm or debunk what was being said. So, if the rev limiter is changed and then returned back to stock, there is no "Big Brother" who has watched and recorded your every move. Basically, no one can tell. Good to know.
However, one can't forget that the rev limiter setting has a purpose, and that purpose is not to save GM money. It's to add boundaries and longevity to that marvelous LS1.:)
Ed
[Modified by C5XTASY, 8:35 PM 12/13/2001]
To this is disturbing
