no back-up lights , please help
Old Apr 7, 2008 | 09:26 PM
oaks99's Avatar
oaks99
Default no back-up lights , please help
i have not back-up lights anybody have any suggestions for me the fuses are all good i checked all of them with a meter .
thanks for your help
oak
Old Apr 7, 2008 | 09:30 PM
tiki240's Avatar
tiki240
have you pulled the bulbs to see if they are good? did you check the fuse box under the hood as well as in the footwell?
Old Apr 7, 2008 | 09:36 PM
c5streak's Avatar
c5streak
Did you check for a corroded ground on the rear frame rail?
oaks99's Avatar
oaks99
yes and yes
oak
Old Apr 7, 2008 | 09:45 PM
c5streak's Avatar
c5streak
Check the tranny switch for voltage?
Jump across it?
Old Apr 7, 2008 | 09:54 PM
oaks99's Avatar
oaks99
Jump across it?
ok thanks
oak
Old Apr 7, 2008 | 10:42 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Is it a manual transmission? If it is, check the switch in the side of the trans case. My C5 has gone through four of them. Unplug the switch, jump it with a paper clip and turn the key on.
Old Apr 8, 2008 | 04:08 PM
oaks99's Avatar
oaks99
i would like to thank all of you who helped me , and it turns out it was the switch
thanks to all
oak
To no back-up lights , please help
