I just lost 77lbs.
Old Apr 8, 2008 | 06:02 PM
dogboy's Avatar
dogboy
Default I just lost 77lbs.
The car that is.
Just for kicks I pulled things out & weighed them. I had to take out the pass side seat because I dropped something under it & couldn't get to it any other way.
Floor mats with the plastic carpet saver. 5lbs
Passenger side sport seat. 44lbs
cargo net 0.5 lbs
rear carpet mat 7.5lbs
hatch covers (all 3) 7 lbs
CD's (10) in holder 1 lbs
plastic targa top holders 0.5lbs
front stabilizer bar 11.5lbs
Total: 77 lbs
Old Apr 8, 2008 | 07:08 PM
YO-EL's Avatar
YO-EL
Originally Posted by dogboy
The car that is.
cargo net 0.5 lbs
Total: 77 lbs
I think your scale is messed up..
Front seat is NOT 44 lbs
3 hatch covers, 7 lbs?? No way bro..
Old Apr 8, 2008 | 11:12 PM
evo2ls1's Avatar
evo2ls1
my frc seats non power weighed 30 lbs so if they are power seats they might be higher
Old Apr 8, 2008 | 11:39 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
If the hatch covers are black, wanna sell them?
Old Apr 9, 2008 | 07:42 AM
AU N EGL's Avatar
AU N EGL
When I took the seats out of my 03 coupe, they weight 44-45 lbs EACH
Those motors for all the power stuff ad weight
Old Apr 9, 2008 | 07:43 AM
9secondflat's Avatar
9secondflat
and i though you were going to say this by eating, pasta, steak, and pizza by using nutrisystems....
Old Apr 9, 2008 | 07:48 AM
dogboy's Avatar
dogboy
Scale is right, I only lost 4 lbs on my diet so far!
Old Apr 9, 2008 | 11:44 AM
C5SCCA's Avatar
C5SCCA
77lbs is a big deal!
Old Apr 9, 2008 | 12:27 PM
9secondflat
i lost 130,
got rid of the x wife
Old Apr 9, 2008 | 02:39 PM
brent brum's Avatar
brent brum
Cruising
rotational mass(going around and around with 130 lb object)not worth it in my book!!!
Old Apr 9, 2008 | 02:50 PM
dogboy's Avatar
dogboy
Originally Posted by 9secondflat
i lost 130,
Hmmm, loss off spousal unit 130 lbs ,
Old Apr 9, 2008 | 08:55 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default hmmmm
dogboy can you elaborate on the hatch covers. Are you refering to the 2 small covers and 1 large cover? I can't see that being 7lbs either.
Old Apr 9, 2008 | 11:37 PM
Bloodvette's Avatar
Bloodvette
i lost 130,
my current configuration is not equipped with the spousal unit, so I'm no expert, but it's an interesting fact that removal of the GF unit is no where near as significant of a weight loss as removal of the spousal module.
Old Apr 10, 2008 | 08:07 AM
9secondflat
typically what you will learn in life, is after the ring gets put on the finger, the weight increases in direct proportion to how much money you spend on your cars over time...
Old Apr 10, 2008 | 09:38 AM
nickolbag's Avatar
nickolbag
Everybody would make fun of me when I took my 10 cds out of my car at the track.
Old Apr 10, 2008 | 10:03 AM
dogboy's Avatar
dogboy
These are the 3 snap down covers under the trunk mat that cover the small side wells and the center one in the coupe. I found it hard to believe myself and weighed them 3 times.
Old Apr 10, 2008 | 11:02 AM
David426's Avatar
David426
Goodyear run flats (all 4 tires) are another 45 pounds of weight you can take off versus non run flats.. Run flats are extremely heavy due to the sidewalls. Borla stinger cat back exhaust saved another 20 lbs over the heavy stock cat back exhaust
To I just lost 77lbs.
Old Apr 10, 2008 | 01:01 PM
robert123's Avatar
robert123
77lbs may be good for.1 sec.
Old Apr 10, 2008 | 02:16 PM
AU N EGL's Avatar
AU N EGL
Ok lets say the car has 380 rwhp. and car AND driver weigh 3377 lbs
ET~ 13.019
speed= 109.60
take out those 77 lbs
380 rwhp car AND driver 3300 lbs
Et 13.013
Speed 110.36
try this for fun http://www.stealth316.com/2-calc-hp-et-mph.htm
Old Apr 10, 2008 | 02:56 PM
nickolbag's Avatar
nickolbag
ET~ 13.019
speed= 109.60
Et 13.013
Speed 110.36
If those are the results then those calculators are good for nothing. Plus they do not factor in where the weight is lost. Lose 100lbs from the interior of the car and it is nothing like losing 100lbs in wheels/tires/rotors. Lose 100lbs in the nose and it is not like losing 100lbs in the rear. Know what I mean?
The general rule is 100lbs=.1 but it is a general rule since there is more to consider than just total weight lost. It may not be a fancy formula like in that link but fancy formulas don't always mean better results.
