Plugs & Wires Question
Old Dec 12, 2001 | 04:15 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Plugs & Wires Question
What kind of improvements can I expect from the NGK TR55's? Also, which wires do you guys prefer, the Taylor brand or The GM Performance wires?
Which MSD ignition works best?
thanks
Zack
Old Dec 12, 2001 | 05:33 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Plugs & Wires Question (y2k02c5)
I just made a post similar to this and most recommended the TR55's. I just bought a set of MSD wires from LAPD, which is what they recommend.
Old Dec 12, 2001 | 05:48 PM
c5vetteman's Avatar
c5vetteman
Check out my signature for my plug and wire selection. Also, I expect a performance improvement, albeit I won't feel it by the seat of my pants.
:cheers:
Old Dec 12, 2001 | 05:54 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Go with NGK TR55 Copper plugs
and
Magnecor Wires.
If your unsure about what kind of wires to use see my post in this thread:
http://forums.corvetteforum.com/zerothread?id=198345
also: http://www.magnecor.com/magnecor1/truth.htm
Also see the C5 tech section for a "how to" I did regarding installation.
[Modified by kewlbrz, 4:00 PM 12/12/2001]
Old Dec 12, 2001 | 06:24 PM
YLWFVR75's Avatar
YLWFVR75
Default Re: Plugs & Wires Question (kewlbrz)
cool thanks for the tips guys!!! :cheers:
Old Dec 12, 2001 | 06:35 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
I've gone w/ NGK TR55 plugs & MSD 8.5mm wires. I changed wires because stock ones kept coming off plugs. The MSD wires have held onto plugs as if glued to them. Regards..
Old Dec 13, 2001 | 12:28 AM
99 Corvette's Avatar
99 Corvette
kewlbrz, I always see high remarks from you about the magnecor wires. What is different/better about them and is there a CF vendor who carries them? Thanks.
Jerry
Old Dec 13, 2001 | 01:41 AM
kewlbrz's Avatar
kewlbrz
Default Re: Plugs & Wires Question (99 Corvette)
Jerry
99 Corvette, see my links above about why. Also I got mine from a local speed shop, I am not sure, but I beleive LAPD and tbyrne.com sells them. also thunderracing.com and horsepowerstore.com
Old Dec 13, 2001 | 01:56 AM
Lashtal's Avatar
Lashtal
Nology Wires and Beru plugs. Working great for me!
I've heard good things about the Magnecore too.
:cheers:
Old Dec 13, 2001 | 11:42 AM
99 Corvette
Jerry
Makes since now. At first I looked at it and only saw your short 2 line post. I understand now. Thanks :cheers:
Jerry
Old Dec 14, 2001 | 05:37 PM
bean0820's Avatar
bean0820
I went with the Taylors and have quite a bit of radio interference. I'm taking them off this weekend...
Old Dec 14, 2001 | 05:49 PM
vettenuts's Avatar
vettenuts
Default Re: Plugs & Wires Question (bean0820)
Glad I saw this, was seriously considering them. Think I will go with the Magnecor. How the heck do you get the old ones off? I can't get them to budge, even though the car only has 1000 miles on it :eek:
Old Dec 15, 2001 | 12:28 AM
Jim 47's Avatar
Jim 47
Default Re: Plugs & Wires Question (vettenuts)
the Magnecor wires are an excellent choice, vettenuts. :yesnod: I've had them on my FRC for about 6 months and am very pleased.
As for the factory wires, just grab hold and pull. Alittle twisting may also help. Some of them are very difficult to get off especially #7. Man you just can't get a grip on that one at all :(
To Plugs & Wires Question
