I have a 02 Z06 that I can put on T-1 sway bars that I ended up with. I was wondering if the ride is to stiff for normal driving and what shocks to use for mainly street use with them. I live in the boonies and some of the roads are a little rough. I am not going to track the car and maybe just a couple of runs on the 1/4 just to see what it will do. I also have bilstein HD shocks but with what I have read they are probably to stiff. I don't think I want to spend the $ on adjustable ones. Any help would be appreciated. Thanks, Ken
Car: not running yet
408 iron block W/ p series procharger and too many other item's too
mention.
mention.
You still work'n on that car. Is this the wrecked one that you bought a while back ?
The sways won't stiffen your ride to badly as long as you don't pre-load them.
You springs are what's going to make your car more stiff than anything else. If you don't go overboard lowering your car, the bilsteins shold be fine.
