Ambient Sensor Missing!
Old Apr 12, 2008 | 09:24 AM
dcd58's Avatar
dcd58
Default Ambient Sensor Missing!
I've always had the code B2647 showing. Today I decided to fix it. Well! to my surprise when I took off the grill to check the sensor wire(thought maybe i be lucky and the wire would be loose) low and behold NO Sensor! I guess the entire sensor fell down somewhere into the dash. Oh well. Looks as if I'm going to keep this code for awhile
Old Apr 12, 2008 | 09:46 AM
65GGvert's Avatar
65GGvert
It must still be disconnected or you wouldn't get a code. It would just measure the temp wherever it is in the dash. I'd look for the connector, but that's just me.
Old Apr 12, 2008 | 09:52 AM
dcd58's Avatar
dcd58
Okay. help here is definitely needed. Where would I start? Do I need to remove panels, I guess so..dumb question. I'm not really into taking my dash apart for a sensor that I was told is for the 'twilight feature" that I never use.
Old Apr 12, 2008 | 11:23 AM
65GGvert's Avatar
65GGvert
We may be talking about two different sensors here. I was referring to the temp sensor behind the small grill by the ignition key. Are you talking about the light sensor on top of the dash? If so, I wouldn't go chasing that one. I have twilight sentinel turned off anyway. Your car may not have come equipped with that option, I don't know. Either way, I don't use mine.
Old Apr 12, 2008 | 12:52 PM
dcd58's Avatar
dcd58
Yes, it's the one on the top of dash. I have that option. When I first got the car I used it,but you need to leave the lid open for it to work and I don't like that. So I haven't used it in 2+yrs. I just was shocked to not see it when i took the grill off!
To Ambient Sensor Missing!
