will LS2 INTAKE FIT ls6 ?
Old Apr 12, 2008 | 01:21 PM
rustyguns's Avatar
rustyguns
Default will LS2 INTAKE FIT ls6 ?
I THINK THE LS2 HAS A 90 mm INTAKE WILL IT FIT THE LS6? ( WHICH IS 80 RIGHT? )
Old Apr 12, 2008 | 03:04 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Yes, it will fit if you get a 90mm TB, but the LS2 is actually a downgrade to the LS6 manifold.
If you have it properly ported it can flow well, but honestly the HP gain is not going to be much either way.
Old Apr 12, 2008 | 03:11 PM
rustyguns's Avatar
rustyguns
how can 90mm vs 80mm be a downgrade? they put diverters in it?
Old Apr 12, 2008 | 03:16 PM
AMRAAM's Avatar
AMRAAM
I have read that it is a downgrade as well. Supposedly it just doesn't flow well.
Old Apr 12, 2008 | 03:22 PM
Former Vendor
The 90mm TB flows more then an 78mm of course, the problem lies inside the LS2 intake, it does not flow as well as an LS6.
Old Apr 12, 2008 | 03:26 PM
rustyguns's Avatar
rustyguns
wow!
Old Apr 12, 2008 | 03:37 PM
Higgs Boson's Avatar
Higgs Boson
Any flow numbers? Common belief is that they have the same exact flow.
Old Apr 12, 2008 | 04:25 PM
TLewis4095's Avatar
TLewis4095
It is not in the runner design, which in itself is good...it is the leakage between the runners due to the "vibration weld" used in the manufacturing process that is causing the leaks. If you have a heads/cam motor then jump to a good ported FAST & add our TB to really top it off, or go with a LS6 & ported stock tb.
Old Apr 12, 2008 | 06:02 PM
grinder11's Avatar
grinder11
Hot Rod, Car Craft, GM Hi Tech Performance, or one of the popular magazines did a comparo quite awhile ago and LOST around 10 H.P. or so. To exaggerate, you COULD put a 90mm TB on 1/2 inch diameter ports, and it STILL wouldn't flow like a 50mm TB would with 1-1/2 inch ports, right? As I said, this is exaggerating, but, as posted, the LS2 manifold is a large step down compared to the LS6.
Old Apr 12, 2008 | 06:07 PM
OhioC5's Avatar
OhioC5
I read the same article, LS2 lost HP. I will try to find a link if you are interested.
Old Apr 12, 2008 | 08:20 PM
coanan's Avatar
coanan
Might help
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
Old Apr 13, 2008 | 10:06 AM
Higgs Boson
Originally Posted by coanan
according to this, the ls2 makes more....
Old Apr 13, 2008 | 11:14 AM
nuck's Avatar
nuck
Interesting. The results aren't typical of the tests I have seen. Maybe the large number of manifolds in the test led to a change over time in the dyno trends.
http://www.gearchatter.com/viewtopic10974.php
http://www.vetteweb.com/tech/vemp_06...o_testing.html
Old Apr 13, 2008 | 11:35 AM
Higgs Boson
I don't think it matters, guys. They are very similar intakes. Basically the same but the LS2 has a larger TB opening. The LS2 has a tad longer runners as well which would normally contribute to more TQ, less HP. It also depends on what engine they are bolted to.
Mags are for ENTERTAINMENT purposes only.
Old Apr 13, 2008 | 12:19 PM
TLewis4095's Avatar
TLewis4095
And TPIS can weld a 90mm round snout onto the LS6, but when it is all added up the FAST is close to the final cost.
Old Apr 13, 2008 | 12:46 PM
rustyguns's Avatar
rustyguns
yeah! magazines and facts are two different things!
Old Apr 13, 2008 | 02:07 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Think about it this way. The LS2 is basically a bored out version of an 01 Z06 engine, if I'm not mistaken.
It has the 01 Z06 cam with 243 heads, but it is 42 c.i. bigger. I guess GM didn't want it to make more power than the Z, so they had to choke it down somewhere.
To will LS2 INTAKE FIT ls6 ?
