Help!
Old Apr 12, 2008 | 01:25 PM
LO PHAT's Avatar
LO PHAT
Default Rear Sway Bar and Alignment - Help Needed
OK ... I was finally fed up with the rear sway bar bushings squeaking, so I read some information on this forum on how to remove, clean, and grease them. It seemed easy enough. However, I've noticed that the lower A-arms have now moved into a more outward position (creating what would be more toe-in on the car). I only removed the nuts (not the bolts through the arms). I did this on the ground as I've always read that sway bars should be mounted in their resting position (not with the suspension hanging).
Help! Why did the A-arms move, and how do I get them back so my recently done alignment doesn't change?
LO PHAT
Update: As there were no replies while I was bolting everything back together, I lifted the rear of the car and torqued the nuts back to spec. I just took the car for a short drive, and, while there was no longer any squeaking, I am still worried about the alignment....
Old Apr 12, 2008 | 05:10 PM
Patches's Avatar
Patches
Removing and replacing the sway bar will not change your alignment settings. The sway bar does connect the two wheels together to resist body roll during cornering but you will not change the alignment simply by loosening and tightening the brackets and/or end links as you've just described.
Old Apr 12, 2008 | 07:02 PM
LO PHAT's Avatar
LO PHAT
I completely agree with you, of course. I consider myself to be very mechanically inclined, and removing the upper bracket bolts and lower bracket nuts certainly should not have adjusted anything on the rear alignment. That said, I am quite certain of what I watched happen and visually measured. The rear A-arm bushings (at the rear of the lower arms) moved in an outward direction by about 2 mm each. When I tightened things back up on the ground they remained in that position. When I then loosened them back up, lifted the car (tires off the ground), and retightened the nuts, they wound up perhaps only 1 mm off of their original position.
Clearly this shouldn't have happened, but it did. My question is, "Why did it happen, and will the A-arms settle back to where they were after some more driving?"
LO PHAT
Old Apr 12, 2008 | 08:25 PM
AssocRacer's Avatar
AssocRacer
LO PHAT
Sounds to me like the alignment shop that did it left something loose. How long ago did you get the alignment done? If it was within the last say 2 or 3 weeks, i'd take it back and tell them to realign it.
Old Apr 12, 2008 | 08:53 PM
LO PHAT's Avatar
LO PHAT
The alignment was technically done a year ago, but the car has only seen about 6,000 miles since that time. I seriously doubt that anything was left loose, but anything is possible at this point. Still, what could have been left loose that would allow the rear of the lower arms to move the way they did?
What I am fearful of is that the A-arm bushings may be wearing out. Even worse, it could be that the bolt holes in the aluminum cradle are slightly worn.
It is also possible (more like very certain) that I am more **** than most, and many people would simply miss observing this ever so slight change in the position of the bushings.
Maybe it is a little of all of the above....
Old Apr 13, 2008 | 12:59 AM
AssocRacer's Avatar
AssocRacer
Well, comming from experience working on alignments, i'm pretty sure that a 2mm movement would be 1.) VERY hard to notice with the naked eye, and 2.) probably would not affect the alignment of the car that significantly. Possibly moving the rear toe from say 2 degrees to 2.10 degrees, which would make a difference if it was a race car, but none on a street car.
Old Apr 13, 2008 | 12:31 PM
LO PHAT's Avatar
LO PHAT
Let me explain a little better so you don't think I'm crazy.
On the outter rear of the rubber bushings in the lower A-arms, there are flat spots on the bushings where they previously rested/rubbed inside of the aluminum cradle. When I was first removing the nuts, I noticed on each side that the flat spot would become visible and then continue to grow outward until it was exposed about 2 mm in length from the edge of the aluminum cradle that created it. As stated above, tightening the nuts back up did nothing to bring the bushings back inward to their original resting position while the car was on the ground. Tightening the nuts with the tires in the air brought the bushings back inward about 1 mm each.
So ... I am at a loss. I know it happened, and it was quite visible to my detail oriented eyes. I just want to know why it happened. Also, do you really think that shifting the rear of each A-arm outward by 1 mm would only create .10 degree difference in toe?
Thank you for the replies,
LO PHAT
Old Apr 13, 2008 | 12:42 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi LO PHAT -
The only way you could get that kind of lateral movement unintentionally would be from wear in the control arm bushings.
The only bolt that you loosened was the one that runs through the lower rear control arm bushing, and the attachment points on the suspension cradle.
These are wear items, and not unreasonable to think that they could get a little sloppy with wear.
I would add that a year is a long time, and I am finding that these cars seem to get beat out of alignment - maybe it is the stiff suspension and the huge tires - but with tires so costly, I would suggest having the alignment checked to protect your tires from undue wear.
best regards -
mqqn
Old Apr 13, 2008 | 12:49 PM
AssocRacer's Avatar
AssocRacer
Originally Posted by mqqn
Hi LO PHAT -
best regards -
mqqn
I agree here. I did forget to mention that most shops recommend getting your alignment checked about every 6 months on your standad, every day driver. There is alot more force on the vette's supension components due to the larger tires and the fact that the car is naturally driven harder. I would suggest getting your alignment checked two or three times a year depending on how much you drive it.
Old Apr 13, 2008 | 03:15 PM
LO PHAT's Avatar
LO PHAT
Good information there, guys. I'm leaning toward worn bushings too.
In studying those pictures, I am curious about two things: 1) Is the toe setting primarily controlled by the adjustable rod rather than the A-arm mounting points? 2) It appears that there are washers on the car pictured (behind the lower A-arm nuts) that are not on my car.
I'll drive the car without worry for now. If the bushings still haven't settled back into their old positions in a week or so, I'll likely get the whole car aligned again.
LO PHAT
Old Apr 13, 2008 | 04:40 PM
AssocRacer's Avatar
AssocRacer
The toe is controlled by tie rods just like it is on the front.
Old Apr 13, 2008 | 10:16 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
LO PHAT
Hi LO PHAT -
Good eye! lol
That car has an aftermarket catback on it, and the owner had used stacks of washers on those bolts to align his catback.
best regards -
mqqn
To Help!
