anyone else having trouble with their head lights
Old Apr 12, 2008 | 01:52 PM
tramminc's Avatar
tramminc
Default anyone else having trouble with their head lights
at times i have to turn the lights on 2 - 3 times before they lift up. I cleane the grounds, it can't be the motors because they both do it. That leaves the switch.
Old Apr 12, 2008 | 02:24 PM
rehirsch8's Avatar
rehirsch8
I have the same problem on occassion and usually when I'm in a hurry. I have seen posts where the switch has been removed from the steering column and the contacts adjusted inside.
Old Apr 12, 2008 | 04:29 PM
DeeGee's Avatar
DeeGee
Before you go to the expense of changing the switch some guys have had success with cleaning the switch with electrical cleaner. Its about $5 at radio Shack. Squirt a good shot into the switch and it may solve the problem.
Hers the change procedure if you decide to go that way
http://forums.corvetteforum.com/show....php?t=1826359
To anyone else having trouble with their head lights
