wheel swap question
Old Apr 12, 2008 | 03:10 PM
razorhead's Avatar
razorhead
Default wheel swap question
I would like to put 17" x 9.5 & 18" X 10.5 C5 Z06 wheels on my regular 2001 coupe will the 1" additional width fit without modification or adapters
Thank's in advance for the help
Old Apr 12, 2008 | 05:48 PM
thetaxman's Avatar
thetaxman
yes
Old Apr 12, 2008 | 06:13 PM
jmzvet's Avatar
jmzvet
Just bolt em on . I ran them for several years and they work great.
Old Apr 12, 2008 | 06:43 PM
CODE4LS1's Avatar
CODE4LS1
The C5 ZO6's do not have tire pressure monitoring sensors though do they? I am looking at putting OEM ZO6 wheels on my '98 C5 and would like to know if I need to tuen off the computer via Tech II or something.
Old Apr 12, 2008 | 06:49 PM
C5forFun's Avatar
C5forFun
Just put the sensors from your stock wheels in. Works great!
Old Apr 12, 2008 | 06:52 PM
C5FORFUN2's Avatar
C5FORFUN2
Yea, what he said!
Old Apr 12, 2008 | 09:46 PM
CODE4LS1's Avatar
CODE4LS1
Will do then, thanks!
Old Apr 13, 2008 | 12:14 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi razorhead -
It's a nice bolt on, the Z06 is identical in terms of wheelwells etc., so you will not have any issues at all.
best regards -
mqqn
Old Apr 15, 2008 | 08:29 PM
XotiK ZO6's Avatar
XotiK ZO6
I had an 03 ZO6 and it had pressure sensors in it. It was new off the dealer lot, so they came that way.
Old Apr 15, 2008 | 10:54 PM
Profit's Avatar
Profit
What happens when you don't use sensors? Do you have a error message infront of you 24/7 ?
Old Apr 15, 2008 | 11:09 PM
jedblanks's Avatar
jedblanks
LF xx RF xx
LR xx RR xx
on the DIC when you scroll in gages to tire pressure
Old Apr 28, 2008 | 02:04 PM
okbkvette's Avatar
okbkvette
I'm getting ready to do the same, putting Z06 style rims, without sensors on my coupe. Seen much discussion about "lowering" on the stock bolts with those rims. Anyone just slap them on, as is, and if so, do they not look right? to much gap between rubber and fender? I'm trying to keep it simple, more of a summer/track wheel on the Z06 rims, and keep my spokes and Goodyears when it gets cold. Want to be able to switch wheels.
Old Apr 28, 2008 | 11:14 PM
okbkvette's Avatar
okbkvette
well, put em on tonight. Like the look, but think I need to do the stock bolt lowering trick. I'd throw in the pics for comments, but can't figure out how to do it.
To wheel swap question
