Another torque converter question.
Old Dec 13, 2001 | 03:11 AM
SR1654's Avatar
SR1654
Default Another torque converter question.
I was wondering if it was really worth it to install a torque converter on a stock 98 A4 w/o changing stock gearing along with it. I am planning on doing the transgo shift kit and will have a custom cam installed shortly, thus my $$$ is running low. I am planning on 3.42's in the future, but don't want to add the tc if it is not gonna make a difference. Any help here would be greatly appreciated. :seeya
Old Dec 13, 2001 | 03:15 AM
intel55's Avatar
intel55
Default Re: Another torque converter question. (SR1654)
If you have 2.73 gears then I would do a tc and 3.42 at the same time. If you have 3.15 gears then you might want to consider keeping those and just putting in a tc. A tc on either 2.73 or 3.15 gears will really wake up a a4.
Old Dec 13, 2001 | 04:27 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
No, it is not! The labor for changing the T/C and the gear is almost the same. Do both at the same time and you will save. If necessary, save the cam for last, like me!
Old Dec 13, 2001 | 10:41 AM
bparker's Avatar
bparker
I agree with the above posts - but to clairfy this - If you have:
2.73 gears = YES wait for the 3.42 gears and the TC intalll @ the same time..
3.15 gears = Just get a hard hitting TC with a high efficiency and go have fun burning up tires on the streets...:yesnod:
To Another torque converter question.
