Well I threw my vented cap on last night and now notice that when starting the car or on the clutch turning or what-have-you the idle drops down to about 500rpm and wants to die.
Is it the cap or did something else fugg up simultaneously? I'm assuming the case pressure could affect the idle somewhat but I want to make sure.
My understanding of the oem PCV system is that it's basically a controlled vacuum leak which has a check valve.
When you circumvent the oem PCV system with a vented oil cap, you've effectively opened the controlled vacuum leak full time, and the PCV check valve is no longer capable of performing it's engineered design function.
If you did this strictly for "looks", it might be better to just glue a small filter to your oem oil cap.
Someone else will chime in and correct me...
If you are running MAF tune only and 02's are working, it should add the necessary fuel to get you back to desired AFR.
Lsx motors blowing out dipsticks is not unusual, I know. My car did same thing but I had a different TB with no provision for the fresh air supply. Pressure builds up with no place to go and comes out through dipstick tube.
The catch can should catch a lot of the oil prior to getting to PCV valve. In theory your system with an open breather will further reduce oil contamination of the intake. Depends on how well the catch can works, how much blowby you have.
If you are in OL and can tune, just take a look at your AFR again and see what you have. If you are in OL, you probably need to modify your tune to compensate for the breather added.
Changing the PCV system in anyway will change the amount of air that ends up in the motor--just a small amount--more noticeable at idle though--however the fuel trims should compensate for the change and adjust itself--It can take 100 miles or so for the trims to change--You can read your trims and see how far off they are--If they are too far off you can adjust the MAF table accordingly and get them back to "0" and the change will happen immediately
The problem is you are now adding "unmetered" air to the engine. That is air (PCV and thru your vented oil cap) that is used in the engine that doesn't go thru the MAS. That will cause idle unstability. Not saying it won't learn itself out, but it does effect things. It was especially troublesome in the older cars with the IAC valve, and I suppose it could with our electronic throttle too, it effects how much air goes thru the throttle body. Because if you have some going around the throttle body(thru the vented oil cap and in thru the PCV, then the throttle body has to close some to keep idle right, but the pcm knows where it "should" have the throttle body at idle, and what the MAS "should " be reading at idle.
What happens when you put a vented oil cap on is that un-metered air is by-passing the MAF sensor and going into the intake manifold via the PCV system. A vented oil cap makes the system "open" instead of "closed" like the OEM PCV configuration. The OEM system accounts for the fresh air going through the PCV flow path ... but with the vented oil cap the MAF sensor can not account for the fresh air going through the PCV flow path and therefore A/F is slightly lean at idle until the ECU can compensate with time.
BTW - if there is a PCV check valve in the system it will still work the same regardless if the system is "open" or "closed" on the fresh air side.
Your the first person that I've heard of blowing the dipstick out without a supercharger.
OP said he had a Fast 90 intake manifold. If he didn't rig up a fresh air make-up line for the PCV system then it's possible that the crankcase pressure could build up and blow out the dipstick. The fresh air line also becomes a route of blow-by gasses when the pressure inside the crankcase gets pretty high.
Maybe he also blocked off the PCV vacuum hose to the intake manifold ... hard to know without seeing the setup. That would certainly do it.
But it does make you wonder if the rings have massive amounts of blow-by for a NA engine to do this is the PCV vacuum hose is connected to the intake manifold, regardless if there was a fresh air line or not.
My guess is something is wrong with the install, the amount of ring blow-by that it would take to create enough pressure to pop the dipstick out of the tube would cause the engine to run very badly if at all.
I'd love to see some pics of the install as well as maybe a diagram or pics of the fresh-air and PCV systems.
Have you driven the car much since the install? Drive the car for about 50 or so miles and the car should re-learn the idle.
Try to avoid "helping the car" by giving it gas.
OMG THIS THREAD IS A GOD SEND!!! Atleast i hope.. My cammed car has this problem and I always just figured it was because of the cam, but one of my buddies busted a bolt off in my head for the valve cover. I have everything nice and tight but i beat there is a leak...
sorry for jacking the tread.. i'm excited fix it right now.
Thanks!
I assume you reinstalled the factory cap to ensure the problem goes away.
Since the PCV valve needs to be lubricated, the catch can should always be located AFTER the PCV valve. (Unless you have a brillo-pad filter catch can, which does allow some oil aerosols to pass on by)
