Help!!!! Catback Install
Old Apr 13, 2008 | 07:28 PM
bcarp's Avatar
bcarp
Default Help!!!! Catback Install
I am in the process of installing my new exhaust system but I think the previous owner removed some of the parts I need when he installed the borla system. Can somebody show me a picture of the muffler hangars? I searched but I couldnt find any. Also if anyone has the part number os what I need that would be a big help also.
Thanks Bob
Old Apr 14, 2008 | 10:31 AM
bcarp's Avatar
bcarp
Anyone?
Old Apr 14, 2008 | 11:15 AM
02gt350's Avatar
02gt350
no pics but, what do you think is missing? the only hangars are the 2 rubber mounts under the crashbar at the back bumper.
Old Apr 14, 2008 | 11:22 AM
bumble-z's Avatar
bumble-z
Thanks Bob
Bob, your profile is not filled out. I'm assuming your asking about a c/5? There are no hangers on a c/5,catback system. There is a two bolt flange w/gasket that goes before going up and over the rear end. Then the muffler part, should have a flat shaped spear that slides into a slot at the rear bumper. This bracket that has a slot in it is held in place w/two nuts. Hope this helps.
Old Apr 14, 2008 | 11:25 AM
vette747's Avatar
vette747
I took some pics when I installed the borla on my friend's Z.
Go on my site and click on the "Borla CatBack on Z06" link.
my site
http://pages.videotron.com/vette747/
I hope it will help.
Last C5's Avatar
Last C5
Do not unbolt or remove the rear hangers, just slip the old system out and the new one in. The bolts are not captured and can push back up into the rear end necessitating removal of the whole rear clip to get them back in place.
Old Apr 14, 2008 | 11:53 AM
bcarp's Avatar
bcarp
my site
Thanks your pics showed me what I am missing. I do not have the brackets on the rear at all. The bolts and nuts are still there though.
Old Apr 14, 2008 | 12:17 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
my site
Hi vette747 -
Nice web site!
best regards -
mqqn
Old Apr 14, 2008 | 01:45 PM
02gt350's Avatar
02gt350
yes i did that....DOH!!!
Old Apr 14, 2008 | 04:36 PM
lenbal's Avatar
lenbal
Check mufflers you took off -- what was holding them up?
Old Apr 14, 2008 | 05:02 PM
bcarp's Avatar
bcarp
Default Borla
It was the Borla System that only had 1 muffler in place of the stock H-pipe so the brackets were near the sway bar
Old Apr 14, 2008 | 05:06 PM
lenbal's Avatar
lenbal
What kind of borla - i just put stingers on mine - 2 mufflers 2 brackets
Look under rear of car to right and left - rubber piece is hanging --
who put on your system -heck maybe they took off the hangers
Old Apr 14, 2008 | 05:10 PM
bcarp's Avatar
bcarp
Default this one
[/QUOTE]
Old Apr 14, 2008 | 06:28 PM
Kamil D.'s Avatar
Kamil D.
do I need to raise the rear of the car up or can I just go over a loading dock to remove the OEM mufflers
Old Apr 14, 2008 | 06:34 PM
Kamil D.'s Avatar
Kamil D.
lenbal's Avatar
lenbal
did u find brackets..
I would use a lift
has to be in the air
Old Apr 14, 2008 | 06:39 PM
lenbal's Avatar
lenbal
when all else fails - read the directions
not sure how those hook up
To Help!!!! Catback Install
Old Apr 14, 2008 | 06:44 PM
Kamil D.'s Avatar
Kamil D.
Old Apr 14, 2008 | 06:54 PM
Villain's Avatar
Villain
You can go over a loading dock but be careful to not go OVER the loading dock.
Old Apr 14, 2008 | 07:06 PM
Kamil D.'s Avatar
Kamil D.
so i dont have to raise the car to let the tire drop down ?
