help valvetrain clatter on z06 question
Old Apr 13, 2008 | 09:18 PM
David426's Avatar
David426
Default help valvetrain clatter on z06 question
im lookin at a z06 with ls6,, has valvetrain noise at idle is this normal
Old Apr 13, 2008 | 09:55 PM
vettenuts's Avatar
vettenuts
If stock, depends. It should be relatively quiet with maybe a little noise. Sometimes the injectors will tick. If it has a noisy valve train and is stock, might want to check other cars.
Old Apr 13, 2008 | 11:09 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi David426 -
Like vettenuts said, it should be fairly quiet, with some ticking from the fuel injectors possible.
I would say that you should not hear anything that I would describe as "clatter" from a stock one.
best regards -
mqqn
Old Apr 13, 2008 | 11:44 PM
BlackZ06's Avatar
BlackZ06
That's a REALLY tough question to answer .... what some might call valvetrain "noise", others might call normal.
The Z06 has very little sound insulation, so you will hear noises from the engine and the drivetrain that, if you are used to most other cars, will sound scary. Yet they are probably perfectly normal.
I would recommend you have a mechanic who knows the Corvette inspect the car before you buy it. The money you spend on an inspection may save you thousands in repairs if there are problems with the engine, clutch, transmission, or differential ..... you are about to pay a lot of money .... buy yourself some "insurance" .... just because someone on the forum says "that's normal" or "that's not right" without ever actually seeing/hearing the car is not a good basis for a buy/no buy decision.
Old Apr 14, 2008 | 07:49 AM
David426's Avatar
David426
thanks a million for the advice
Old Apr 14, 2008 | 10:16 AM
lucky131969's Avatar
lucky131969
Old Apr 14, 2008 | 10:51 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Guys -
I give the OP credit for being able to discern valve clatter from the normal mechanical noises that normally emanate from the gen III engines.
He has been a member here since 2004 and in his title described VALVETRAIN CLATTER.
He currently drives an LS1.
No - I cannot diagnose valve problems via internet postings, but I can say that anything that I would describe as CLATTER coming from a LS6 is not normal.
best regards -
mqqn
Old Apr 14, 2008 | 11:51 AM
lucky131969
Originally Posted by mqqn
Hi Guys -
Fair enough...then why is he soliciting forum members if he is capable of discerning the noise himself?
Old Apr 14, 2008 | 11:58 AM
bumble-z's Avatar
bumble-z
If car is equipped w/ after market headers, the noise would be magnified.
Old Apr 14, 2008 | 12:01 PM
David426's Avatar
David426
i never had valvetrain issue with my Ls1.. I called a local tuner 21st century musclecars and they said its normao on the ls6.. So did my Huffines Chevrolet Serviceman. Its definately not piston slap which is common on the ls-1.. Seems like I'm getting mixed answers here.. I just don't want to have any regrets if i buy the car.. Thanks again
Old Apr 14, 2008 | 12:07 PM
lucky131969
Nothing mixed about what BlackZ06 suggested. Get the car to a qualified corvette mechanic, and put your concerns at rest. If the seller is not agreeable to letting you get the car checked out, I would move on...
Old Apr 14, 2008 | 12:14 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi lucky -
He is able to discern something on the LS6 that seems abnormal to him, from his experience with an LS1. He is asking people who have experience with an LS6 if they notice it and is it normal.
Since I have both an LS1 and an LS6, I submit that I do not hear significant valve train noise from the LS6 as compared to my LS1.
I apologize if I somehow make people uncomfortable with my replies.
mqqn
Old Apr 14, 2008 | 12:33 PM
lucky131969
Hi lucky -
mqqn
Seems totally subjective to me. My feeling is, if you have to ask, then you don't know. If it is even questionable, then get the car to a mech who can evaluate said noise. Simple as that.
I have no idea how your replies make people feel uncomfortable.....
Old Apr 14, 2008 | 09:32 PM
FDKSS's Avatar
FDKSS
3rd Gear
I have a 01 Z with 46k miles and you can hear the valvetrain if your outside the car or windows down. louder them my 02 SS camaro for sure.
Old Apr 15, 2008 | 02:18 PM
David426's Avatar
David426
thanks for the input guys.. The owner is taking it to a local tuner 21st century muscle cars.. These guys specialize in the Gen 3 Ls1/ls6 based cars.. They will go over the car with a fine tooth comb. including a compression/leak down test. The owner did tell me that some clater is normal on these engines
To help valvetrain clatter on z06 question
