No mouse-over for you!
Just kidding! This thing is absolutely awesome; extremely easy to install and looks very clean installed. Not only that but Sean's service was top notch, providing a very detailed CD with instructions including his phone number in the event that I needed help with anything.
A couple installed pictures:
This is a shot of where I ran the positive wiring from the solenoid:
Another shot where I ran the same wire from the weatherstripping to the wiring harness hole in the firewall:
Thanks alot for a killer product at an excellent price Sean!
Where did you install your activation button in the car? Could we see a pic?
Sorry I didn't get a shot of that. ATM it's in the ashtray but is just a loose switch. I'm going to hold off on hard-mounting it until i fabricate the switch panel for my nitrous system.
Yes, I have agree with you. Sean's kits are awesome. You can't beat the price on them. If you don't have one get one from him. He installed mine last night and it works great. Thanks Sean.
That burnout you did last night was freaking awesome!
Man, i read the thread title and i felt bad for Fastbird. After paying the supporting vendor fee and everything, I'm sure it was costly. glad to know it works well.
No it does not. Bled mine on one side for awhile and the wife started to complain about her leg. Once the drivers side was bled it took about two pumps on the passenger side.
We bled/cleaned the clutch afterwards and then we worked the kinks out of her leg later......
Install was really smooth and lines were bent correctly.
Installed the plate and solenoid
Installed the pre bent lines
Grounded here
Wired into the cigarette lighter and used the ground on the drivers side tunnel area for the LED grounding
ZO6PSI, thanks for posting the pics! I'm going to try to get them up on my website as soon as I can get internet support in my billeting room again. Same goes for you j0n and deathstrike.
