Supercharger Question?
Old Dec 13, 2001 | 02:51 PM
bobroz's Avatar
bobroz
Default Supercharger Question?
This might be a stupid question but I'm going to ask it anyway. I just had The Vette Doctors install their Stage 2 Heads and cam package.(Awsome job). What does it entail to have the Magnuson supercharger installed. Can I use the new heads and cam? Is it worth installing the supercharger? I had the Z06 manifold installed w/ the head and cam package. Damn I wish I was a motorhead. Thanx Bob
Old Dec 13, 2001 | 03:32 PM
TomC5's Avatar
TomC5
Default Re: Supercharger Question? (bobroz)
Bob,
I think you might have a problem. Most people that machine the heads do an .030 cut on them and that will raise your compression. Not really a problem on your setup but it is not what you want on a supercharged motor. The cam is also the "heart" of any motor and it needs to be matched to a specific application. Although the Magneson supercharger is a low boost setup it is not aftercooled and it will be pumpung hot air into the motor. I am still not convinced that this setup will not loose horswpower under higher outside temps.
Tom
Old Dec 13, 2001 | 06:12 PM
Peach's Avatar
Peach
Orlando Events Coordinator
Cruise-In II Veteran
Default Re: Supercharger Question? (TomC5)
Bob,
Tom
Tom, I hope they ge these questions answered soon. I have the Cartek stg 2 set up. I also am thinking about the Magnason SC on top of this.
Old Dec 14, 2001 | 09:33 PM
VERTVETTE's Avatar
VERTVETTE
To much cash for 50hp. You shpuld have probably went with the blower 185hp for around the same money and a three year war.
Old Dec 14, 2001 | 10:32 PM
MHLY01's Avatar
MHLY01
Default Re: Supercharger Question? (VERTVETTE)
You will not get near a 185hp from magnuson blower. Its a given.
COmpression will be too high as well with regular H/C. You will get detonation problems.
Old Dec 15, 2001 | 05:01 PM
Dave68's Avatar
Dave68
Default Re: Supercharger Question? (MHLY01)
Wellllll, you might want to check out this thread - 185 HP MINIMUM from a Procharger supercharger! (not the same brand, but very impressive)
http://forums.corvetteforum.com/zerothread?id=200525
Old Dec 15, 2001 | 05:13 PM
intel55's Avatar
intel55
You may want to check out the Procharger. Your h/c and cam will work fine. The Magnuson is a good roots type blower, but will only support a limited amount of boost and hp. If you increase the boost on the Magnuson you will quickly detonate because the lobes will heat of the air greatly. To counteract this you would need an aftercooler, which usually sits under a roots blower, another 3 inches in height. A centrifugal blower(Procharger) is much more efficent and does not have nearly the amount of drag on the engine. It is also do heat the air up as much. It fits under the hood and comes with twin intercoolers. The Procharger 1DSC I think supports up to 950 horses at the crank. :cheers:
To Supercharger Question?
