Oil Pressure Sender Trouble
Old Apr 15, 2008 | 05:23 PM
Tomx64's Avatar
Tomx64
3rd Gear
Default Oil Pressure Sender Trouble
I replaced my oil pressure sender last week. It worked fine until today. Now it's pegged again. How long are these things suppose to last ?
Old Apr 15, 2008 | 05:55 PM
MattB's Avatar
MattB
The first time I changed mine it lasted a week. Don't get a GM or Delco sensor. I got a borg warner sensor, from NAPA I think. Make sure you set the torque correctly, some think that over torquing even a little causes them to fail. The borg warner is on a second engine LOL...
Old Apr 15, 2008 | 06:07 PM
Tomx64's Avatar
Tomx64
3rd Gear
Thanks I'll try that.
Old Apr 15, 2008 | 11:22 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Look at the topic at the top of this Tech area. There is a lot of information about the oil pressure sender failures up there.
Old Apr 18, 2008 | 03:59 PM
joe_121212's Avatar
joe_121212
I replaced mine with a Duralast from Autozone. $37 bucks and
its been about 3 months now.
Old Apr 18, 2008 | 04:28 PM
J.R.'s Avatar
J.R.
Look at the above thread on relocating sender unit.
It takes a few adaptors and a section of braided line. This lets you change sending unit from drivers side of engine by engine coils. Saves from having to pull intake when these alum. sending units go bad (which they do frequently). The remote let's you use a brass Buick sending unit.
Old Apr 18, 2008 | 06:30 PM
randy814u's Avatar
randy814u
I under torqued mine a couple pounds, and that was a year and a half ago.
Old Apr 18, 2008 | 07:08 PM
SpeedUp's Avatar
SpeedUp
what torque did you use? i just did mine with the 'cut' method and torqued to 15lbs.
To Oil Pressure Sender Trouble
