Approximately how much fluid will I use (full flush)? My current fluid is clear, but I was 'lied' to and apparently it is standard, off the shelf generic DOT 3.
I have 3 pints of Motul and I surely hope this will be enough, I guess the trick will be 'overbleed' since the current fluid is clear so I can't use color change as a way of determining when I am flushed.
I use ATE and flush from blue to clear and back on my track car all the time. A full flush and refill of the clutch reservoir will take a less than a quart.
there is a slight difference in color/clearness, watch it closely as it comes out of the caliper. G/L
