CEL codes
Old Apr 18, 2008 | 04:09 PM
Bigstik's Avatar
Bigstik
Default CEL codes
I installed dynatech LT and High flow cats this past winter. I know that codes are normal until it gets tuned to eliminate the rear O2 sensors, but I wanted to make sure that I am not getting any unneccesary codes. Here are the 4 that I get most of the time.
P0153 - Slow response Bank 2 sensor 1
P0135- Heater Circuit Bank 1 Sensor 1
P0141- Heater Circuit Bank 1 Sensor 2
And P1153- Insufficient Switching Bank 2 Sensor 1
I might be missing 1 but that all i could remember.
Do i need to fix something or are these normal?
Thanks for the help
Nick
Old Apr 18, 2008 | 08:22 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
Thanks for the help
Nick
I have been getting the first and also the Po133c which is the bank 1 both of these are for the front sensors. Just bought new GM front sensors and 12" flat to flat extensions. After several starts and about 50 miles I am still good. I got my fingers crossed. I wish I new what to tell you so far as a fix but apparently most header installs will trigger these codes. Some guys will have the tuner turn the particular code off so you see no indicator. If I continue to have these codes I may have that done other than throwing the codes the car runs like it always has. Good luck with yours.
Old May 5, 2008 | 01:20 PM
pcruiser73's Avatar
pcruiser73
Thanks for the help
Nick
Why are you tuning out the back sensors with this system? Do you not have 4 sensors anymore? My dynatech supermaxx system still had provisions for the rear sensors and I have no codes at all coming from them. The front ones on the other hand I get P0135, P0154, and P0155, which I am having a helluva time trying to fix.
To CEL codes
