Changing rear diff fluid
Old May 1, 2008 | 05:25 PM
pm0084's Avatar
pm0084
Default Changing rear diff fluid
This may seem like a no brainer, but I want to change out the fluid on my 01 C5 it only has about 16000 miles on her, so due to tiime I thought it would be a good idea. My question is does the 01 C5 have a drain plug or do you have to remove the cover. The dealer wants 160.00. They said they remove the cover to inspect the parts...I don't want the cover removed because it does not leak and I know once the stealership does work it probably will start.
Old May 1, 2008 | 06:03 PM
Mike94ZLT1's Avatar
Mike94ZLT1
It is probably the rear cover, which isn't what usually leaks on these cars, but I doubt for $160 they even do that. Honestly, at 16K I wouldn't mess with it, but if it makes you feel better go for it. Do it yourself, it is easy. Jack the car up (level, you will see why later), you will see on the bottom there is a drain plug. Drain it out, and let it sit for a few because it will take awhile to drain. Put the plug back in. There is another plug on the back on the passenger side. Pull it out, and you want 2 bottles of rear end juice (I like the Redline 75w90 myself) and for good measure get a tube of limited slip additive. You will probably want to go to the parts store and get a cheap fluid transfer pump for this part. With the car level like I mentioned before, start pumping fluid in there. When the first bottle gets halfway down, pour the limited slip additive in that bottle, and continue pumping away. Move on to the second bottle, and keep filling. You will get most of the second bottle in, and fluid will start coming out the fill hole. Stop at this point, let it stop running out, put the plug back in place, wipe the rear down where the fluid dripped, and you're done. Should cost you about $35 in fluids, including the cost of the cheap transfer pump.
Old May 1, 2008 | 06:07 PM
pm0084's Avatar
pm0084
Thats what I thought.... thanks for the reply....just wanted to double check.
Old May 1, 2008 | 06:42 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Ummm, If you do what Mike says, you'll end up blowing something up.
just kidding mike
Old May 1, 2008 | 07:18 PM
Last C5's Avatar
Last C5
Mike,
I use the Redline 75/90 too and it already has limited slip additive in it. I've never added additional to either my DD or my track car and it works fine. The Redline 75/90ns is the one that needs additive.
Doug
Old May 2, 2008 | 12:24 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi pm0084 -
There is a drain plug on the differential.
Here is a link to some pictures that may help -
http://www.iammoon.com/images/c5tech/diffoil/
best regards -
mqqn
Old May 2, 2008 | 07:26 AM
65GGvert's Avatar
65GGvert
The local Chevy dealer just drained and refilled mine (including additive) for $89. Check with another dealer if you want it done for you.
Old May 2, 2008 | 08:51 AM
stingray71's Avatar
stingray71
Just make sure you can get the fill plug loose before you remove the drain plug.
Old May 2, 2008 | 10:03 AM
jovette's Avatar
jovette
Would not be good to drain old out and not be able to get the new in.
Old May 2, 2008 | 12:01 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
diff fluid is good for 50,000 miles. Save your money for gas
Old May 2, 2008 | 10:42 PM
97C5owner's Avatar
97C5owner
Didn't mike just blow up his rear end??!! JK mike. Sorry to hear about it, and thanks for the scoop. I'm about due for a little differential PM myself.
Old May 3, 2008 | 12:38 AM
C5XTASY's Avatar
C5XTASY
Just finished a 500 mile break-in on my new 3.73s.
Would it be wise to replace the differential fluid?
Ed
Old May 4, 2008 | 10:40 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Ed -
Did the vendor of the diff recommend that?
It surely would not hurt anything, and at two quarts it would not cost a lot if you wanted to do it.
There would be no reason to do this from the perspective of contaminants or metallic shavings from gears polishing in - if the rear is set up properly - in my opinion.
best regards -
mqqn
Old May 4, 2008 | 10:20 PM
pm0084's Avatar
pm0084
I got around to doing my fluid change today everything went smooth, thanks for the post and great pictures. I went with Mobil 1 and some LSD additive if anyone was interested.
Thanks again
Old May 5, 2008 | 08:44 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Paul -
Glad the pics helped.
I have pics of the manual trans fluid change as well, just change diffoil to transoil in the link I posted.
best regards -
mqqn
Old May 5, 2008 | 11:31 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What size bit do you need to get the fittings off the differential?
Old May 5, 2008 | 11:50 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Sigforty -
It is a 10mm hex wrench (allen wrench...)
best regards -
mqqn
Old May 5, 2008 | 12:30 PM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
I Remember With My C4 They Recommended 2 Tubes Of The Limitted Slip Additive. Has This Changed With The C5?
Old May 5, 2008 | 01:43 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi UWEBABY -
It depends on what you are adding - GM does specify adding friction modifier into the C5 differential, but some of the aftermarket gear lubes already contain this additive.
best regards -
mqqn
To Changing rear diff fluid
