Bolt hole question
Old Apr 19, 2008 | 12:11 AM
verano29's Avatar
verano29
Default Bolt hole question
I'm currently cleaning out the bolt holes. I'm using a bolt with the side ground down (a home made bolt chaser) which was recommended by several individiuals. One question however, should I fail to get a little "gunk" out of the bottom of the hole how much distance from the tip of the bolt (when its fully inserted) to the end of the bolt hole. I hope there is a fair amount as I don't want to bottom out in the bolt hole and crack the block.
Old Apr 19, 2008 | 08:34 AM
vettenuts's Avatar
vettenuts
I used a little brake cleaner and long Q-tips to clean the bottom of the hole. You should be able to get them pretty clean.
