30lb Injector question...
Old Apr 20, 2008 | 05:27 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Default 30lb Injector question...
Asking for opinions from you knowledgeable guys about these injectors, planning on putting Z06 cam, LS6 heads/intake on a mostly stock 2000, will these be a good addition. Thanks....
http://forums.corvetteforum.com/show....php?t=1997525
Old Apr 20, 2008 | 05:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Shouldn't need injectors for your planned mods, your 26# stock ones will be plenty adequate.
But yes, those 30s will work fine, and if you do decide to buy them, you will need tuning adjustments to compensate for the additional fuel flow.
Meaning, don't install them until you or your tuner can make those corrections. If you have to drive to the tuner, leave your stock ones in and swap the injectors while at the tuning shop.
Old Apr 20, 2008 | 07:03 PM
renegad44's Avatar
renegad44
Thanks for your input Y2K, appreciate it.....
Old Apr 20, 2008 | 09:12 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Old Apr 20, 2008 | 11:24 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Originally Posted by Todd157k
Not needed---and you would be creating some extra tuning work--you must have the 30# er's inputted into your IFR table and will have to re adjust all your fuel trims again--
Old Apr 21, 2008 | 01:02 AM
SLPRC5's Avatar
SLPRC5
Sound like you have your answer...26# may very well handle your mods.
Your installer/tuner will tell you which is better to use..
Good luck Bro...
Old Apr 22, 2008 | 12:25 AM
renegad44's Avatar
renegad44
OK, thanks bro/guys, I've already made the purchase on the 30lb injectors, so I'll see what my tuner/installer has to say as far as which way I should go. Good points...thanks....
To 30lb Injector question...
