Corsa Install Issue
Old Apr 21, 2008 | 09:43 PM
Twin Screws's Avatar
Twin Screws
Default Corsa Install Issue
Installed the system in my 01 Z...rattling coming from the passengers side exhaust...the over axle pipe is leaning too much towards the outside of the car and is rattling against the car...anyone have this issue? Solutions?
Is there some type of heat resistant pad I can use between the pipe and car?
Old Apr 21, 2008 | 09:46 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Its not adjusted correctly. Put the rear up on some ramps and readjust it. Its not hard.
Search for CORSA INSTALL.
Post some pictures: that will help.
Old Apr 21, 2008 | 09:54 PM
Twin Screws
Default Corsa
You can't adjust the over axle pipe. You can only adjust the muffler...
Old Apr 29, 2008 | 12:57 PM
nelswhytry's Avatar
nelswhytry
I have a similar issue with my install. The over the axle pipe on the passenger side is really close to the sway bar, I think it rattles against there sometimes. Hopefully I will get a chance this weekend to try to adjust it.
To Corsa Install Issue
