Brake torque specs
Old Apr 21, 2008 | 10:02 PM
Bobtam's Avatar
Bobtam
Default Brake torque specs
I'm putting new brakes and rotors all around on my 03 Z06 and need the torque specs for the caliper mounting brackets. I saw a posting that C4's are 166 lb/ft. Is it the same for a C5? They were tough getting off. Should I use loctite.
Got a great deal from Gene at GM Warehouse on the brakes.
Old Apr 21, 2008 | 10:43 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
125 lb/ft for the caliper bracket bolts. Make sure to use some Loctite Red on them too.
Old Apr 21, 2008 | 10:47 PM
bigbadbevo's Avatar
bigbadbevo
Yep. 125 ft-lbs. and red loc-tite. I do recall they were a biatch to remove when I replaced mine.
Old Apr 25, 2008 | 07:58 PM
SDLS1Rider's Avatar
SDLS1Rider
What type of red loctite? I have two tubes, a 242 and a 271. The 271 says remove with heat or special tools.
Old Apr 26, 2008 | 12:22 PM
SDLS1Rider's Avatar
SDLS1Rider
Bump, I'm going in today (rotors and pads). If you don't hear from me in two days send in the Marines.
Old Apr 26, 2008 | 03:48 PM
hotwheels57's Avatar
hotwheels57
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Old Apr 26, 2008 | 08:18 PM
Bill Dearborn's Avatar
Bill Dearborn
The bolts from GM come with a red thread locker material already installed on them. I change my brake rotors several times per track season and have just stopped bothering with the thread locker. Tightening the bolts to 125 I have never had one without thread locker come loose.
Bill
Old Apr 26, 2008 | 10:10 PM
SDLS1Rider's Avatar
SDLS1Rider
I did it! All of the new rotors and Hawk brake pads are back on. Torqued to proper specs and I accomplished the Stop Tech bed in procedure.
To Brake torque specs
