help with dieseling problem
Old Apr 22, 2008 | 03:33 AM
shaggy911's Avatar
shaggy911
Default help with dieseling problem
my C5 Z06 2003 with 30k miles started dieseling today.
it isnt a severe dieseling issue. it lasts for about a 0.5-1 sec at most.
i replaced the plugs and wires the weekend before last, with
Iridium tipped plugs (0.04 pre-gapped) part # 12571164
Red wire kit part # 89017270
Gas is (always) 92 octane filled recently.
I have been running fuel injector cleaner for the past 3 tanks but not the current one.
When i had purchased it (as used) a month ago, it had an odd ping (once or twice as opposed to severe detonation) on cold start and in low rpm and low speed situations. So i have been running injector cleaner for a while and i didnt hear any ping.
i did a search and found the following causes:
1. carbon build up (i havent been driving it hard; too much traffic; snow/mild-heavy showers. But i doubt this could be the issue)
2. Hot plug (iridium tips are ok as far as i know. But this set could be defective. Should i have had the plugs replaced with the platinums that the car came with?)
3. faulty/failing injector (
4. timing (unlikely)
i did a search here and it seems that this could be
1. normal issue with these cars (disengage clutch to avoid sputter/dieseling)
2. Throw out bearing
Any clues what could be running hot or what could be causing this?
Old Apr 22, 2008 | 06:58 AM
DefenderC5's Avatar
DefenderC5
Question: Does this occur when you turn off the car when the car is in neutral and the clutch is out? Does the dieseling condition you describe still occur if you shut off the car with the clutch in and while in gear?
If the sound does not occur while turning off the car with the clutch in... it is not dieseling. It would be the infamous "death rattle". Which is also 100% normal.
Try this first and see if the condition is still occuring.
Old Apr 22, 2008 | 09:17 AM
jovette's Avatar
jovette
Can't diesel for very long..........once you turn the ignition key off, the fuel injectors quit working.........can't diesel without a fuel source. Usually dieseling is result of a hot engine, fast idel, and continuous source of fuel, as in old engines with carburator, and mechanical fuel pump. How is your idel speed and engine temp?
Old Apr 22, 2008 | 09:27 AM
lucky131969's Avatar
lucky131969
True, unless you have a leaky injector. Do pressure test a the fuel rail.
Old Apr 22, 2008 | 12:36 PM
shaggy911's Avatar
shaggy911
with the clutch fully in, there isnt any rattle. So i am assuming all is well.
To help with dieseling problem
