Code P 1416
Old Apr 22, 2008 | 04:45 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default Code P 1416
Says AIR System bank 2 -B
is this the vaccuum pump, or check valve or where should I look first
Old Apr 22, 2008 | 05:17 PM
BlackZ06's Avatar
BlackZ06
It is most likely a check valve ...... there are two codes .... P1415 and P1416 ..... each assigned to one side of the engine.
When you are driving the PCM "tests" the AIR pump by firing it up and watching the O2 sensors to make sure they read lean. If one side doesn't pass, the appropriate DTC is set. If your pump was dead, you'd get both sides failing which sets a P0410 sets .... only one side says it is not the pump.
Try the WD40 "trick" .... if you SEARCH on P1416 and/or P1415 you will find a description of blowing WD40 into the system, followed with compressed air.
Old Apr 22, 2008 | 09:23 PM
vetteman9368
St. Jude Donor '08
thanks
Old Apr 22, 2008 | 09:43 PM
ericdwong's Avatar
ericdwong
I hate that damn code, I've had to replace my check valve twice and its always the one behind the intake manifold (P1416)...
Old Jun 10, 2008 | 04:37 PM
Dookie's Avatar
Dookie
Cruising
is there a problem with not fixing this right away?
Old Jun 10, 2008 | 04:42 PM
vetteman9368
St. Jude Donor '08
hasn't been a problem for me. I haven't messed with it, still gets good fuel economy, feels fast
To Code P 1416
