I am absolutely stumped
Old Apr 25, 2008 | 03:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Apr 25, 2008 | 05:34 PM
KamiLos's Avatar
KamiLos
The people asking whether the FRC is a 6spd or a4 followed by a solution should really get the corvette models down before suggesting taking out plugs, etc.
Old Apr 25, 2008 | 08:17 PM
99FRC Newb's Avatar
99FRC Newb
Originally Posted by Oldvetter
On the fuel cutoff setting with the column lock re-program, maybe someone reprogramed from 2 mph to 120 mph. Just a thought. Have you had this car when it would do over 120 mph?
i did have the column lock recall done sometime in october
Originally Posted by Billdog350
Besides the obvious "rev" or "speed" limit by the PCM, one other factor might be kicking in here....Cat protection mode. If I recall, the pcm will go WAY rich if it thinks your cats are overheating. This will dump MASSIVE amounts of fuel in as well as cutting spark in an attempt to get exhaust (cat)temps down. A tuner would see this with a wideband on a dyno (as well as black smoke at WOT) . This could be putting a "speed" limit on long high speed pulls.....which I'm sure you're doing at a local track, RIGHT?
ofcourse its at the track
Originally Posted by nj02vette
Are you sure it doesn't have 4.56 gears.........
Very high gearing could affect your top speed, but I also doubt that it would stop a 5k, should go all the way to redline.
Let us know and thanks for your service
i THINK the car has 3.73's. not completely sure.
the cars revs all the way through 1st-3rd no problem.
the video is processing on youtube. i should have it up in a little bit.
Old Apr 25, 2008 | 08:32 PM
BlackZ06's Avatar
BlackZ06
That won't affect you .... the engine would shut off completely if, by some weird quirk, the column lock fuel shutoff was invoked at 120 instead of 2 MPH ..... that's not your problem.
Again ... not your problem ......
OK, that's important ... now if you can do it, as I asked in post #10 .... if you're in 4th and hit 120 and it won't go faster ... what happens if you select 5th ????
I'll check the video as soon as it's up ... but it sure sounds like someone altered your MAX SPEED setting for 4th gear, as I said in the earlier post.
Old Apr 25, 2008 | 08:38 PM
99FRC Newb's Avatar
99FRC Newb
Originally Posted by gpracer1
This will sound funny, but I once had a superbike I bought used that would not rev out in the taller gears. Checked EVERTYTHING, then said oh well so much for racing this weekend.....might as well change the oil. It holds 3 quarts and had 6 in it!!!!!!!!!!!!!!!!!!!!!!!!!
After that it ran like a raped ape.
just changed the oil. still nothing
Originally Posted by tblu92
Is it an automatic or a 6 speed ?? If it is a 6 speed and you are trying to run WOT in 6th gear--it probably won't pull it in 6th over 120and you are just running out of power--Try it in 5th at WOT--
Could also be a slipping clutch--
If it is an automatic--I would check the trans fluid--could be low on oil-
It really needs to have some data logging otherwise as it could be so many things--Check injector duty cycles---fuel pressure--Actual timing at WOT--Also could be bad fuel--try another station--If you are continually getting spark knock--it will eventually drop into the "low octane table" making it a total dog under a big load---(flat out @ WOT)
i've been through about 8k miles of gas since the problem started
Originally Posted by minitech
Is it possible it is just guilt? Speed laws max out around 75 mph at the most on the street!
i have no conscience. guilt isn't an issue
sorry, must have missed that. won't accelerate any faster in 5th either
Old Apr 25, 2008 | 08:42 PM
99FRC Newb's Avatar
99FRC Newb
http://youtube.com/watch?v=gu48q2fW2Ns
and i was wrong earlier. at the end of the run, it throws 2 codes.
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
but they go away after a minute or so.
and keep in mind i no longer have cats.
*edit* because of the angle, it looks like i was at redline, but i wasn't. getting close, but not at 6k
Old Apr 25, 2008 | 08:47 PM
BlackZ06's Avatar
BlackZ06
Sure sounds like someone either intentionally or unintentionally has speed limited your car. I know that products like EFILive and HPTuners would allow you to quickly get in and see what is going on .... I don't think a dealer could help with a Tech2, other than to re-load a whole new set of software into the PCM.
Any idea if the car was taken to a "tuner" in the past ??
If you can redline 1,2, and 3 ...... and you can't redline 4th ... it has to be the PCM ..... the engine itself doesn't know or care about gear selected, but the PCM can calculate the selected gear (RPM and road speed) so it has to be the PCM ....
Old Apr 25, 2008 | 08:52 PM
99FRC Newb's Avatar
99FRC Newb
when i first bought the car, it was fine. i got it almost to 170.
it had the trans overhauled in november, didn't really mess around much in the winter, but now it doesn't want to go past 120.
unless the place that did the trans tuned my PCM, it should have the stock tune
*edit* with no load on the wheels, it will redline 4th and 5th no problem
Old Apr 25, 2008 | 09:11 PM
BlackZ06's Avatar
BlackZ06
Dude,
Your profile says you are a "Benz Service Writer" .... how do you feel when a customer brings in a car, gives you ...
a) partial information .....
b) incorrect information .....
and expects you to figure out the problem ....
You said in your original post "it does not throw any codes." ... yet your CHECK ENGINE light is glowing brighter than the sun (and your seatbelt warning is ON also ... I'm gonna assume you havve other codes besides engine codes .... NOBODY would do a run to 120 without their belt on .... right ???) .... and now you throw out "and keep in mind i no longer have cats." .....
What else aren't you telling us ???
The P0137 and 0157 are most likely the issue ..... the PCM sees the Heated O2 sensors reporting a VERY lean condition and is running the engine very rich. You are way down on horsepower. You don't notice it in the lower gears, there is enough HP to get the car to redline .... but you don't have the HP to reach redline in 4th, 5th, or obviously 6th.
You need to fix the O2 sensors, you may have melted wiring on your exhaust and they are shorted, or they have been damaged and are not reporting the correct O2 content ....
Let us know if you want to fix it before you take off ....
Old Apr 25, 2008 | 10:40 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I'm going to have to go with door #2. I got a feeling like you have some left over restriction in your exhaust. A piece of cat material maybe??? Not enough restriction to keep it from running properly until you go WOT. Since it doesn't take too long, pull the exhaust and check it from end to end.
Old Apr 25, 2008 | 10:41 PM
BLOWNBLUEZ06
If you have an X pipe, look in that. Could be one side blocked.
Old Apr 25, 2008 | 10:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Steve
Yep,,,,,,,,,,,,,you nailed that one down to the footer!!! As soon as I saw the U Tube video I saw the CEL and said the SAME THING! WTF???
There's a code in there some where! CODES TELL ALL!
BC
Old Apr 25, 2008 | 11:35 PM
  #33
kettemr's Avatar
kettemr
Fouled plugs?
Old Apr 25, 2008 | 11:51 PM
  #34
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by kettemr
Fouled plugs?
1st,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2nd, ,,,,,,,,,,,,,,3 rd ,,,,,,,&,,,,,,4th,,,,,,,,,,,,,,,,,,,,,al l,,,,go to RED LINE !!! Plugs are N O T an ISSUE!!!
BC
Old Apr 26, 2008 | 12:44 AM
  #35
BlackZ06's Avatar
BlackZ06
Fouled plugs?
I'm trying really hard to start the weekend as a "nice" guy .... but man you two are pushing my limits .....
Fouled plugs ????????? Mis-fire (code P0300) ....... and he'd have the problem in all gears ..... and he'd be complaining of a rough idle .... What (name just one) "symptom" led you to diagnose the problem as "fouled plugs" ???
Restricted exhaust ???? Again, please name (just one) symptom that led you to that conclusion ????
And if it helps, guys, his PCM has already given us the answer .... P0137 and P0157 .........
BOTH of his O2 sensors are DEAD or something is causing him to run incredibly lean. The PCM expects to see the O2 sensors reporting in a range of anywhere from 10 mV (Way Way LEAN) to 1,000 mV (super RICH) and to set the DTC the two O2 sensors have to be reporting consistently (for over 6 minutes) at less than 80 mV.
Until these codes are fixed (and I suspect there may be others) playing with other stuff in the engine is pointless. The PCM is unable to "manage" the engine properly .... as I said earlier .... he is way down on Horse Power with these codes.
Old Apr 26, 2008 | 02:52 AM
  #36
99FRC Newb's Avatar
99FRC Newb
thank you for taking care of that before i could jump back online.
Originally Posted by Bill Curlee
Steve
BC
The check engine light is because i just installed an Off Road X Pipe. p0420 and p0430 are setting the check engine light. those have nothing to do with my problem. ignore the light
Old Apr 26, 2008 | 02:47 PM
  #37
99FRC Newb's Avatar
99FRC Newb
and just to clarify, it ONLY throws those 2 codes when i am trying to top the car out like that. i have never seen them other than that
To I am absolutely stumped
Old Apr 26, 2008 | 08:01 PM
  #38
kettemr's Avatar
kettemr
Sorry I'm not meeting up to your standards. I suggested fouled plugs as sometimes something simple is overlooked in these situations.... I'm not diagnosing anything but I thought the point of this forum is to get help and ideas from other forum members.
As for symptoms, I had a similar situation with a past vehicle where the top speed was limited well below normal. No rough idle, no rev problems in any other gears. After weeks of trying to figure out the problem, it turned out to be the plugs which were not even that old.
Thought sharing my nearly identical experience may help someone else.
Old Apr 26, 2008 | 09:33 PM
  #39
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Speaking of spark plugs causing a car to run out of power,,,,I helped a forum member from France. TORCHED VETTE His car was doing something simular.
His car is supercharged and in the upper RPMs under power would start misfiring and limiting power. Turned out to be that his plugs were gapped WAY too large and his spark would blow out. Simple regap of the plugs and PROBLEM SOLVED! So, sometimes its best to listen to all the recommendations and suggestions and run it through the check process.
I agree with BLACKZO6 in that is not plugs because it runs OK in the lower gear range but dies under really heavy loads.
Check those O2 sensors and get rid of those damn codes.
BC
Old Apr 27, 2008 | 12:22 AM
  #40
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Bill--Hi----hey just a thought--Guessing that the problem happens while he's at WOT--Won't the 02 sensor codes have nothing to do with a WOT run ?? The car should be in PE mode and in "open loop drive" meaning that it's not running off the 02's in closed loop anyway ---It still may be lean in closed loop--that's whay he's getting the codes-AND it is probably lean in PE open loop as well if the problem is a general fueling issue that affects it in both closed and open loop modes-
I don't think you would get a lean 02 code on PE open loop mode----
What do you think ???----maybe it is NOT going into PE open loop--could be they got the O2 wires crossed from front to back ??
