Help with Borla straight pipes
Old Apr 25, 2008 | 07:42 PM
rockzo6's Avatar
rockzo6
Default Help with Borla straight pipes
I just got a set of Borla pipes, they look like the back holf of the XR-1. I only bought the over the axle pipes and not the x-pipe. The question is how do these bolt up in the rear and to what? Pics would be greatly appreciated.
Thanks in advance,
Greg
Old Apr 25, 2008 | 07:52 PM
DsC5's Avatar
DsC5
If you follow the stock exhaust forward from the mufflers you'll come to a flange with two bolts. The straight pipes will bolt up right there.
Old Apr 25, 2008 | 08:00 PM
rockzo6's Avatar
rockzo6
I have them bolted to the H-pipe. I guess I should have been more specific. Where do the 2 tabs on the back half of the pipes bolt to? The 2 tabs sit right next to the center storage wll box on bottom.
Old Apr 26, 2008 | 12:47 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
They bolt up to the lower sway bar bolts. I loved those pipes, just hated those small tips. Good luck
Cajun
Old Apr 26, 2008 | 01:50 AM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
my tabs were horizontal and drilled outwards, I wound up using a long 3/8ths bolt, some tubing around it and tapped the frame rail.....it actually spread the pipes a bit but it kept the exhaust from hanging.
of course my car is gutted road course track rat with no plates. I'm not exactly worried about pretty. Light weight and obnoxious would be a bit more fitting of a description....
Old Apr 26, 2008 | 04:34 PM
rockzo6's Avatar
rockzo6
Yes my tabs are horizontal too. So where do these bolt up. I don't think I am an idiot but I can't figure this out. I have looked and looked and tried the pipes on each side with each tip section and still no luck.
Greg
Old Apr 26, 2008 | 07:15 PM
AU N EGL's Avatar
AU N EGL
Cajun
Yup the lower sway bar bolts
Not borlas but still straight pipes
To Help with Borla straight pipes
