temperature sensor
Old Apr 27, 2008 | 12:07 AM
drace99's Avatar
drace99
Default temperature sensor
When I removed the plastic piece that covers the temp sensor (the piece directly to the left of the ignition switch), something was missing. I had a wire with an empty connector. Does anyone know the part number of the piece I am missing? What does it do exactly, because everything seems to be working well!
Or should I stick with if it ain't broke don't fix it?
Old Apr 27, 2008 | 12:23 AM
MagRedConv's Avatar
MagRedConv
It's the interior temp sensor. Check the forum vendors on the left side of the page, I'm sure you'll find one there.
Old Apr 27, 2008 | 09:22 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do you have auto climate controls? If not, then don't worry about it. It is part of the auto climate controls, If I remember correctly.
Old Apr 27, 2008 | 09:37 AM
Bugaboo's Avatar
Bugaboo
I agree, you could be seeing wiring for something the previous owner had in there for God knows what. If your sensor is working properly the disconnected wiring CANT be for it anyhow.
Old Apr 27, 2008 | 10:24 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
When I put my column lock bypass in for the first time, this is where I found my sensor :
Except it was wire tied to one of the braces in the dash. I always wondered why my temp inside the car couldn't be properly regulated. It appeared that during one of the many dealer attempts to fix my column lock, they just wire tied it inside the dash, instead of actually trying to reinsert it into the proper location (which can be a little tricky).
Anyway, the sensor should look like the above picture if it's all still intact.
Old Apr 27, 2008 | 10:29 AM
LoneStarFRC's Avatar
LoneStarFRC
No CJ2 HVAC system, no sensor.
Old Apr 27, 2008 | 11:21 AM
Bugaboo's Avatar
Bugaboo
Man, there's a highly skilled "technician forya" Seen better stuff from shadetree mechanics!
Old May 1, 2008 | 04:36 PM
drace99's Avatar
drace99
Default part number
Does anyone have the temp. sensor part number and best place to get one?
Old May 1, 2008 | 06:53 PM
BlackZ06's Avatar
BlackZ06
Part number 16267411
can be bought from forum supporting vendors such as ...
http://www.gmpartsdirect.com
http://www.gmpartshouse.com
To temperature sensor
