Mobil 1 oil == crap??
Short roundup... Valvoline DuraBlend is half the price of mobil1 and twice the oil. Royal Purple kicked everyone's a$$.
http://www.animegame.com/cars/Oil%20Tests.pdf
I don't know why it's on 'animegaem.com'. The commodore site has some excellent articles in their tech section.
if you can find this part in my LS1...
getting striked like this in normal useage - in that exact manner - then I'd look into these other oils.
This is nothing except a slideruler -type- simulation test that doesn't mimick the actual useage of the engine.
Real World Testing... is all that counts.
This is nothing except a slideruler -type- test that doesn't mimick the real world useage of the engine.
http://forums.corvetteforum.com/show...t=high+mileage
1st & 16th post.
Does more need to be said?
1st & 16th post.
The proof is in his puddin! Can't beat that for real world style.
Mobil 1 is widely available, has been proven to be an excellent oil in real-world use, and is reasonably-priced compared to many other top-tier synthetic oils.
Personally, I've run M1 10w-30 in the following cars:
'00 hardtop: 165,xxx miles, autocrossed regularly
'94 Z-28 (LT-1): 207,xxx miles (daily work car)
'96 Crown Vic (4.6l V8): 240.xxx miles before I sold the car for our
'03 CV: 105,xxx miles (family car)
Oil change intevals on all these cars is around 7500 miles, (~40% left on the OLM for our hardtop), and had engine oil analysis done; oil was always in good shape.
BTW, oil analysis saved the '96 CV engine when it found traces of coolant in the oil, as well as increasing trends in wear metals. Investigation found a failed intake plenum gasket that was leaking. No external symptoms other than the phantom coolant loss. www.blackstone-labs.com labs does good work for $20 per analysis.
HTH, and have a good one,
Mike
Last edited by VetteDrmr; Apr 29, 2008 at 08:38 AM. Reason: Corrected Blackstone website address
Without going in to all the details, all synthetic oils are not alike. At one time Mobil1 and Amsoil, among a very few others used a Polyalphaolefin (PAO) base oil. This is an expensive product and justified Mobil1's $5.00 - $7.00 per quart price. Roughly 2 years ago people who routinely perform oil analysis began to get reports back that their Mobil1 oil was now using a much less expensive Group III base stock. But Mobil1 continued to cost as much or more than when it was based on the PAO base stock. In short, a marketing decision had been made to increase profits by using cheaper Group III base stock, while charging the same price. Naturally, Exxon-Mobil did not advertise that they had lowered the quality of their product. Rather, they touted their "reformulation" without giving any details. This is all the more significant when one considers that Mobil spent decades telling the public how good their full synthetic oil was compared to the competition precisely BECAUSE it used the PAO base oil, with its acknowledged benefits over the less expensive Group III.
So is the current Mobile1 a bad oil? No. But for less money you can buy an equally good oil such as Pennzoil Platinum, Castrol Syntec, Quaker State, etc. If you don't mind spending $7.00 per quart, Amsoil is still a PAO based oil. I also think Royal Purple and/or Redline may be PAO based oils.
That advantage of the PAO base is its excellent cold weather properties and resistance to breakdown in high heat conditions. Our 'vettes run hot. The better the resistance to thermal breakdown the better the oil will protect our engines.
If you still wish more information, do check out bobistheoilguy.com.
Glen
Glen,
FYI, Red Line advertises that they use a Group V Polyol Ester vice the Group IV PAO that AMSOIL uses in all of its synthetics expect its least expensive XL line. The polyol esters behave differently with regards to porous materials (like seals) and I felt more comfortable with AMSOIL when I made my shift from Mobil 1 to AMSOIL back in 2004.
I chose to stay away from Royal Purple for similar reasons to what you listed above for Exxon-Mobil. Royal Purple's website does not say what basestock they use, thus I assume it is predominantly Group III, probably with some PAO and Ester's blended in for improved performance over the typical Group III synthetic on the market today.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Scumbags!!
What oil does he use? Plain ole' Valvoline dino. He changes it every 3-5K miles.
I know because of related engine heat, we have to use Synthetic. Anyway, my point is, if changed regularly, a Mobil 1 engine can go several 100K miles without issues.
