how do I pull codes?
Old Apr 27, 2008 | 03:04 PM
lomoman's Avatar
lomoman
Default how do I pull codes?
My ck eng light came on today and the engine has a slight ticking noise. Could someone tell me how to pull the codes that might point me in the right direction. First day out of storage (4 months). Its a 2000 FRC 6sp. Thanks for any help you can give.
Old Apr 27, 2008 | 03:24 PM
thetaxman's Avatar
thetaxman
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES". Press OPTIONS to go to the next module. Repeat the steps in this paragraph until you have reset the codes in all the computer modules. NOTE !! Only reset the codes IF you want to - it is NOT necessary to do this.
