Spark Plug Gap? Help.
Old Dec 15, 2001 | 12:19 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Spark Plug Gap? Help.
I plan to install NGK TR55s and I've read that the gap should be .055 to .060. With my mods listed in my sig. and my a/f ratios go from the high 12s at lower rpms to the very low 12s at the highest rpms, where should I set the gap? Thanks.
Old Dec 15, 2001 | 01:58 PM
C5Cemo's Avatar
C5Cemo
Default Re: Spark Plug Gap? Help. (Rippied Z06)
I think .050 would be a good start. then you can go out and do a couple diagnostic runs to make sure your A/F is where you want it.
But, with your combination I'd really consider some TR6's as an option as well.
:cheers:
