Service Column Lock
Old Apr 29, 2008 | 10:40 AM
leviathan125's Avatar
leviathan125
Default Service Column Lock
This morning I got the "remove key and wait 10 seconds" displayed. This has happened a hand full of times before. So, like always, I removed the key and waited. This time though, the "service column lock" came on the display and the car dies. This has never happened before. The steering wheel is NOT locked. I have no idea if the car has had any recalls done before. How can I check to see?
Is a CLB already installed since the steering wheel doesn't lock? Or could that be from one of the recalls installed?
I did a quick search before I made this thread, but I didn't find any solutions right away.
Old Apr 29, 2008 | 01:59 PM
dougbfresh's Avatar
dougbfresh
You probably have one of the 1/2 a$$ fixes from GM installed. Your in security mode now, it will start and die if you go over 2mph. Pull the bottom of the dash and see if a CLB has been installed (unlikely).
Old Apr 29, 2008 | 02:13 PM
bluvette79's Avatar
bluvette79
if the steering does not lock when you shut the car off and you can hear the lock actuator moving, the lock has been deactivated but you probably do not have a clb installed unless it has gone bad. the dealer has done several fixes but none of them work. get a clb (column lock bypass) from one of the form vendors (i think i got mine through corvettes of houston for $50). check the stickie above or search vendor section for clb and get one and install it.
Old Apr 29, 2008 | 09:24 PM
leviathan125
I am fixing to order a CL bypass. Once I install it will the problem go away or will it not fix it since the problem is already there?
Old Apr 29, 2008 | 10:20 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
It will take care of it , just follow the instructions. Corvettes of Houston is a good place to buy it from, they have lots of experience with these. Do it before your steering locks though.......it will not unlock a frozen column.
Old Apr 29, 2008 | 11:42 PM
2fat2fly's Avatar
2fat2fly
I had a similar problem a couple weeks ago.This is the thread from my adventure:
http://forums.corvetteforum.com/show....php?t=1996062
I have some diagrams and info that will probably help you.If you want it PM me your email and I will send it to you.I hope you get it solved quickly.
Old Apr 30, 2008 | 12:04 AM
mvvette97's Avatar
mvvette97
I got the service column lock the other day while driving. I was running about 50 when it done it. It didn't die or anything. I stopped and shut the car off and restarted it and haven't seen it since. I also have the CLB from corvettes of Houston and still got the message
Old Apr 30, 2008 | 12:23 AM
yamablaster024's Avatar
yamablaster024
Im in the same boat as you. Im in the process of building my column lock bypass.
Old Apr 30, 2008 | 12:05 PM
leviathan125
Thanks for the help everyone. I went a head and ordered the CLB from Corvettes of Houston. So hopefully when I receive it I will be able to drive the Vette again. I guess I could drive it right now....at 2 mph.
To Service Column Lock
