Getting Gas Everyday
Old Apr 29, 2008 | 01:38 PM
jedblanks's Avatar
jedblanks
Default Getting Gas Everyday
I got sick of paying $60 per fillup, so I started getting gas every day on the way home from work. $7 per trip. (yes I know it works out the same, but makes me feel better).
Are there any issues with keeping the tank completely full? 2 gallons at a time? If so, I might start letting it drain to 1/2 tank before refilling.
Also, there seems to be a range of 1 gallon (sometimes it takes 1.5, sometimes 2.5 for same trip/same conditions). Normal due to two gas tanks?
Old Apr 29, 2008 | 01:41 PM
candacedianne's Avatar
candacedianne
Just make sure you "fill up" in the morning or after the sun has gone down. I forgot why they said to do that, but it helps retain better gas mileage. Buy a K&N too, that will help with gas mileage a little.
Old Apr 29, 2008 | 01:44 PM
largodon's Avatar
largodon
Cruising
If you are going to get gas everyday, why not keep the less full? if you can keep 8 gallons out of the tank, that is 50+ lbs out of the car. You might actually come out ahead in fuel consumption since you will not be carrying around that additional 50lbs.
just my .02
Old Apr 29, 2008 | 01:50 PM
jedblanks's Avatar
jedblanks
Good point on the less lbs, but by that logic, I could stand to lose about 50 lbs myself. Hasn't stopped me from eating LOL.
And if I keep the gas tank less full, and don't fill it up, then I have no real way of tracking my mileage.
Mainly I just wanted to know in theory if there are any problems I could cause by continually keeping it full.
Old Apr 29, 2008 | 01:53 PM
David426's Avatar
David426
i pulled 4 of my plug wires off... So I'm actually running on 4 cylinders... Mileage is great!
Old Apr 29, 2008 | 02:13 PM
AMRAAM's Avatar
AMRAAM
I can't confirm nor deny this statement, but it is said to fill up when it's cool because of the expansion and density of gasses in the heat.
Old Apr 29, 2008 | 02:36 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You should have unplugged 4 injectors!!
Old Apr 29, 2008 | 02:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The fuel is more dense when its cold and the more dense it is the (theoretically ) the more you get for your $4.00. I think it's bunch of because the temp of the ground below the frost line doesn't vary more than a few degrees one way or the other in a season! . It takes a LONG time for the ground temp to change. so, that theory doesn't make any sense. The only time the fuel in the ground tank will change temp is when its filled by the tanker truck.
The fuel in the pump can be effected by daily temp changes but,,,there probably isn't more than 1 - 1 1/2 gallons in the pumps hose and meter thats exposed to the outside temp. Then it comes out of the tank in the ground,, and its again at the ground level temp any way!
When you fill your tank, don't keep topping it off (cramming gas in) until it fills the inlet pipe. You will cause the fuel to flood the vent purge valve and charcoal canister and the car will run rich until it clears its self out. It will also set a DTC. (cant remember which one) Ask me how I know this!
BC
Old Apr 29, 2008 | 02:39 PM
BLOWNBLUEZ06
I attribute some of the fuel pump failures in Texas and other hot areas to the fact that the fuel keeps the pump cool by the fuel running through it as well as by having the pump submersed in it. I have seen many GM pump failures and I believe one of the causes is from running the tank low all of the time. The other major cause is not changing the fuel filter thus causing additional resistance in the line, forcing the pump to constantly work harder. Keeping the tank reasonably full will help the pump live. Also might help the fuel sending unit corrosion issue that many have with these cars.
Old Apr 29, 2008 | 03:07 PM
Corvette Don's Avatar
Corvette Don
Dont give me any ideas
Old Apr 29, 2008 | 03:38 PM
candacedianne
Yeah, I cannot either, but I figure 'what the heck'-if anything, it won't hurt the car
Old Apr 29, 2008 | 03:40 PM
C5SCCA's Avatar
C5SCCA
Theres some good common sense! The whole basis for ground source heat pumps is a little shot if the temperature in the ground fluctuates THAT much and on a daily basis.
Old Apr 29, 2008 | 03:50 PM
AMRAAM's Avatar
AMRAAM
What I read was that it is up to the consumer to decide whether or not it is worth the possible inconvenience for the minimal savings. i think the number they gave was 31.00/year. And that is assuming there is any credibility to that theory at all
Old Apr 29, 2008 | 04:38 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
This is
Old Apr 29, 2008 | 04:52 PM
c5streak's Avatar
c5streak
I would guess this would be true on any system which uses recirc fuel to cool the pump. I know for a FACT (don't ask!) that '98 to '02 Dodge diesels will lose a fuel pump($$$$) if you run the tank at a low level all the time in hot weather. Besides that, I learned from the Fire Service, ALWAYS keep the tanks full. You never know when or where you might have to go!
Old Apr 29, 2008 | 05:11 PM
hotwheels57's Avatar
hotwheels57
...people debate and claim over the silliest things. If you want to fill up in the p.m. instead of a.m., that's your choice.
My choice is to fill up at 1/2 tank. No logic or thought process involved, it's my choice. My name is on the titles and no one else is paying for my fuel.
You might find that fuel has gone up another .05 cents in those eight hours of work, but it's still your car to do with as you please.
Old Apr 29, 2008 | 05:46 PM
Plasticfan's Avatar
Plasticfan
To Getting Gas Everyday
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
WOAH! .05 cents.....not sure where you work....but in the morning gas could be $3.20. By night time its gone up to $3.45! Saw that one happen about a week ago here.
Old Apr 29, 2008 | 06:34 PM
stormrider's Avatar
stormrider
BC
Since I am in the business I can confirm that once again BC is right on the money.
Old Apr 29, 2008 | 07:00 PM
DRR's Avatar
DRR
Here in Cali we went to double containment tanks a few years ago. The fuel comes to the station in a shiny s/s tanker, warmed by the sun. Then into a tank that is now insulated by a secondary containment that prevents leakage as well as heat transfer.
You can check this yourself by feeling the supply hose (not the vent hose) while filling your tank. It is not cooler than ambient temp as it would have been in a single layer tank.
Around here the underground temp is ~54 degrees F. They want to sell you warm fuel because it expands and the pumps are not temp compensated.
As for getting gas every day. That is not helping. But it will not hurt to keep the tanks full.
