Air conditioning compressor replacement write-up
Old Jan 18, 2011 | 06:20 PM
  #41
RealmSteel's Avatar
RealmSteel
Is the link for this down again?
Old Jan 19, 2011 | 12:01 AM
  #42
frodo84's Avatar
frodo84
Uneducated autodidact
Old Jan 21, 2011 | 08:47 AM
  #43
scott1974's Avatar
scott1974
Not working for me either. Can someone PM me the PDF?
Old Mar 18, 2011 | 10:51 AM
  #44
scott1974's Avatar
scott1974
Will someone send me the PDF? Link isn't working.
Old Apr 10, 2011 | 02:34 PM
  #45
midlifetoy1's Avatar
midlifetoy1
Default ac compressor replacement
Same problem here. can I get a copy also?
Old Apr 11, 2011 | 01:00 PM
  #46
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Can I hire you to replace my compressor? Mine is leaking and my system won't hold a charge for more than a year at a time at the moment.
Old Jun 20, 2011 | 06:12 PM
  #47
RedWuken's Avatar
RedWuken
Great write up. Unfortunately after 15 hours of work my new AC wouldn't hold pressure for more than 5 minutes. Looks like I'll be taking it to the shop anyway.
Update: Turns out it was a single mis-sized o-ring at the condenser. Shop charged me $100 to complete the job, $50 of which was for the refrigerant I hadn't yet put in. So ~$50 in labor as apposed to hundreds. Next time I might just take it to the shop though. Don't let the write-up fool you, this is a ridiculous project.
Old Aug 15, 2011 | 11:14 AM
  #48
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Thanks for the write-up. I found this to actually be really easy as opposed to many of the other things I have done on my car ha. My ac works great now! Only problem I had was that when I connected by battery back up the actuators didnt synchronize right and my air was hot on driver side cold on passenger side ha. Quick fix though luckily, just disconnected the battery and connected it back.
Old Aug 12, 2012 | 11:55 AM
  #49
dlmiv's Avatar
dlmiv
5th Gear
Rocco, Thanks for the great write up! I hope I never have to become that intimate with my A/C unit, but if she ever decides to leave me all hot and sweaty, I now have the knowledge of how to get her back without being taken to the cleaners. Thanks!
Old Aug 20, 2012 | 01:41 PM
  #50
Rebel44's Avatar
Rebel44
4th Gear
Default Thank You !!!
Rocco you da man. Thanks for taking the time and making the effort to do such a superb job of documenting your A/C work experience.
Hopefully, I will take full advantage of your efforts within the next few days.
1998 Torch Red Coupe
Old Aug 20, 2012 | 11:33 PM
  #51
_r2h's Avatar
_r2h
Great write up!
Old Jan 22, 2014 | 01:12 AM
  #52
jmfol's Avatar
jmfol
Rocco,
Thanks for the great write-up. I printed it and followed it step by step when replacing my dead AC compressor on my ‘01 C5
As everybody else, I struggled when trying to remove the darn 13-mm screw holding the hoses on the back of the AC compressor.
Instead of using a socket and a bunch of 1/4-in drive extensions, or remove the RH exhaust manifold, I found it easier to use a 13-mm craftsman combo ratchet wrench from the inside of the wheel well.
Here is the wrench that I am talking about. P/N is 42424 (case someone ask, I don't work for Sears).
The way the compressor is mounted, I did not have enough space for the wrench to rotate more than one click between the engine craddle and the right rail. So what I did is to first remove the compressor from its mount by loosening the 2 screws and the stud, and shifted the compressor by about one inch toward the right frame rail. I temporary secured it in this position with a wood spacer (see pic below)
Now it gave me just enough stroke from the wrench to rotate two clicks
After that, taking out the 13-mm screw was a breeze, you just had to be patient as you can only ratchet it out 2 clicks at a time… But nice thing is that you are able to see what you are doing.
Did the reverse for tightening it back to the new compressor.
Hope it helps,
JM
Old Jan 22, 2014 | 09:22 AM
  #53
RoccoC5's Avatar
RoccoC5
Thanks for the tip and pictures!
Old May 12, 2014 | 05:46 PM
  #54
mako2222's Avatar
mako2222
I'm new to the forum. how do I save tis article please.
Old May 16, 2014 | 08:04 PM
  #55
Remow2112's Avatar
Remow2112
Default For those struggling with the bolt on the back of the compressor.
Don't fight with it. Pull the bolts that hold the compressor on and pull it towards the passenger side fender. This gives you plenty of room to pull the bolt that holds the back hoses.
Of course, put it back on before you reattach the compressor to the engine block.
HTH,
Dan...
Originally Posted by jmfol
Rocco,
Hope it helps,
JM
Old May 24, 2014 | 10:36 AM
  #56
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Great DIY write up! Thanks!
Old Jun 22, 2014 | 08:07 AM
  #57
jmrochelle's Avatar
jmrochelle
2nd Gear
I can see why my compressor went bad, and I know why the car seemed to run hot on cool days. ( I have a 160 termo )
It is worse than it looks too!
must have been the owner before me
To Air conditioning compressor replacement write-up
Old Jun 23, 2014 | 01:17 PM
  #58
mako2222's Avatar
mako2222
thanks, I will check mine.
Old Aug 19, 2016 | 07:40 PM
  #59
James2000's Avatar
James2000
EXCELLENT WRITE UP!!! My AC is making a tapping/clicking whining sound that increases as I hit the gas. AC blows ice cold, but I'm assuming not for long. Your write up, is my Chiltons manual. Haha..... Thank u for taking the guess work out of this project. Now if you could only take the sweat work out of it....... LOL.......
Old Aug 19, 2016 | 11:43 PM
  #60
old stingray's Avatar
old stingray
Great job,excellent write up and pics. Thanks
