What is your ride height
Old Dec 17, 2001 | 11:29 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: What is your ride height (AZ99FRC)
Obvioisly I think that lowered (and Stock) cars should sport the Frame Savers and Rocker Rails but you know what else really helps? Take a razor knife and after marking a nice straight line accross the bottom, trim about an inch off the air dam . Do all 3 pieces. The center piece is tougher but you can do it. It makes a world of difference! If the line is a little crooked , just sand it smooth with some 36 grit sand paper.
ANDY
Old Dec 17, 2001 | 12:08 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: What is your ride height (Andy@AandACorvette)
I'm at 26" even in the front and 26.75" in the rear.
I have Bilstein Sports and 265x35x18 tires in front and 295x35x18 rear.
I have trimmed the jounce bumpers on the front shocks 1/2".
I also trimmed 1.5 inches off the front air dam.
And I love it this way :D
Old Dec 17, 2001 | 02:52 PM
RichieRich's Avatar
RichieRich
Default Re: What is your ride height ('98 Six Speed)
^ ttt
Come on guys, I've got the second highest car in this thread even after lowering it! I'm going to try to lower it a little more on the stock bolts this week. Anyone in the SJ / SF Bay Area willing to give me a hand if I can't get it just right? I don't know how to cut the bushings.
Help is much appreciated!
Old Dec 17, 2001 | 04:03 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: What is your ride height (MelloYellow)
Which suspension do you have?
started life with the soft FE1 then changed to stuff in my sig.
Old Dec 17, 2001 | 04:04 PM
VettesRule's Avatar
VettesRule
I lowered mine to the maximum adjustment. No cutting of the bushing allowed in SCCA super stock.
Front - 26.8
Rear - 28.0
[Modified by VettesRule, 5:49 PM 12/17/2001]
Old Dec 18, 2001 | 08:00 PM
vettethret's Avatar
vettethret
2002 Z51.
25 3/4 IN BACK
25 5/8 IN FRONT.
BACK IS BOUNCY BECAUSE OF LITTLE SUSPESION TRAVEL. I AM TRYING TO FIND A SHORTER SHOCK, I HAVE ALREADY CUT OFF 50% OF THE BUSHING, SHOCK IS A BILSTEIN SPORT.
Old Dec 18, 2001 | 09:14 PM
Paradigm's Avatar
Paradigm
Default Re: What is your ride height (vettethret)
That IS low.
Old Dec 18, 2001 | 09:20 PM
vettethret's Avatar
vettethret
YES SIR- THE LOWER THE CAR GOES, THE MORE BEAUTIFUL IT BECOMES. :D
Old Dec 18, 2001 | 09:31 PM
Paradigm's Avatar
Paradigm
can you post some pics? I'd like to view your C5.
Old Dec 18, 2001 | 09:35 PM
vettethret's Avatar
vettethret
I CAN GET AHOLD OF A DIGITAL CAMERA BUT I DONT KNOW HOW TO POST IT?
Old Dec 18, 2001 | 09:49 PM
CMilVette's Avatar
CMilVette
Vettethret, you can send them to cmilburn@bbnow.net, and I will post them for you if you want......... :cheers:
Old Dec 18, 2001 | 10:02 PM
MelloYellow's Avatar
MelloYellow
Andy @ A&A gave me 2 good tips on how to get back 1.5" of travel from your Z51 Shock!
Flip rear mounting brackets upside down & mount that way. Looks funny but works. Gets you back .5" travel.
Take the shock mount hole & drill it out oblong higher up the shock about .5". Weld 2x 5/8" spacers .5" higher. Gets you back another .5"
Cut bump stops .5"
Lowered 1.5" and increased shock travel 1.5" !
My goal is 26.5" Front & 27.25" Rear after my new wheels/tires go on.
Anyone want to shoot any holes in any of this?
I'll do the bump stops & brackets for sure.
Old Dec 19, 2001 | 05:49 PM
  #33
vettethret's Avatar
vettethret
Default Re: What is your ride height (CMilVette)
:yesnod: Thanks for the offer. I will send them as soon as my buddy comes over with his digital camera.
Thanks Again
Old Dec 20, 2001 | 01:20 PM
  #34
vettethret's Avatar
vettethret
Default Re: What is your ride height (seanr)
DO YOU HAVE ANY PICTURES
Old Dec 20, 2001 | 05:01 PM
  #35
Flyin'Brian
Cruise-In I Veteran
Cut bump stops .5"
These are some good tips :yesnod:
Old Dec 20, 2001 | 06:09 PM
  #36
vettethret's Avatar
vettethret
THANKS FOR THE POST. IM SO FED UP AT THIS POINT THAT I'M THINKING OF DISHING OUT THE DOUGH FOR BREATHLESS PERFORMANCE COIL OVERS, BREATHLESS SAYS THEIR 2.5" SHORTER THAN BILSTIENS.I'LL BE PRAYING TO THE KING THAT THIS STRAIGHTENS OUT MY MINI-TRUCK RIDE. :confused:
