Power Steering Pulley?
May 2, 2008 | 12:22 PM
Who makes a good one? Is there one that isn't solid, so you can get at the bolt that's trapped on the stock model? Thanks.
Edit: LS6 motor, stock.
May 2, 2008 | 01:00 PM
I took a hole saw and cut a couple of 1" holes in the pulley opposite of eachother and at different differences from the center.
I put a 13 mm socket through and loostened the pump perfectly.
It does not make a vibration or anything and certianly didn't weaken it.
good luck
May 2, 2008 | 04:42 PM
St. Jude Donor '17-'18-'19
May 2, 2008 | 04:47 PM
Use the stock GM aluminum LS2 pulley. It has "spokes", is the same diameter, is cheap and is a "plug-n-play" (no mods of any kind). Problem solved
Part # 12568997
HTH
May 4, 2008 | 01:36 AM
Quote:
Originally Posted by
LoneStarFRC
Part # 12568997
HTH
I did the same. This pulley is steel and less than $20 from the dealer.
If you like polished billet aluminum than RevXtreme is the way to go.
May 4, 2008 | 02:48 AM
Good advice given. Go get the LS2 pulley and be done with it. No problems to deal with.
May 4, 2008 | 10:35 AM
May 5, 2008 | 04:41 PM
May 5, 2008 | 05:48 PM
TLewis4095
Those are beauty's Tracy.
May 5, 2008 | 07:46 PM
They are all machined very well. I like all of mine a lot and you can't beat the price at all.
