Over heating C5
Old May 2, 2008 | 02:12 PM
Speedygonz72's Avatar
Speedygonz72
Navigator
Default Over heating C5
Recently installed a new Stage II D1SC procharger kit on my C5 due to some over heating issues I was having with the original Stage I kit and have not seen a difference in temperature change.
Car is running around 228 degrees in 65 degree weather and can't think of what will happen when it hits 80 degrees or more.
Car produces 592 RWHP, changed out to a 160 degree thermostat, Dewitt 4 core aluminum radiator. I do have SLP headers that are coated. Also reinstalled the dual fans which was part of the advantage of going from the Stage I kit to the Stage II.
Anyone have any idea of steps I could take to change get my car to run any cooler?
Old May 2, 2008 | 02:38 PM
VinnyT's Avatar
VinnyT
Have you recalibrated the fans to come on earlier?
Old May 2, 2008 | 03:08 PM
reneeautumn's Avatar
reneeautumn
Default coolant overheating solved
Here's what i did.. dewit's rad.,180 stat,fans reprog., install spal twin fans,replace solid foglight bezels with open mesh design. Now car stays between 180º & 190º. Next, installing maxi cool b&m tranny cooler to solve tranny fld. overheating. 99vette procharger stage2 with twin inter coolers, 4l60e rpm tranny/vigilante 2600 stall torque converter etc. etc. 641rwh/553ft @ 6200. @ 8.5lbs boost Hope this helps.
Old May 2, 2008 | 06:51 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
This is me thinking out loud. Things that cause over heating are fueling, timing, blown head gaskets, air pockets in the engine, mis-reading coolant temp sensor, trash in front of the radiator, the deflector missing below the car which creates a high pressure front area and a low pressure rear area on the radiator, cracked block or heads, water pump not flowing properly, thermostat not opening properly, fan wiring reversed causing fans to blow and not suck air through, collapsed radiator hose or any other restriction in the system, defective radiator cap.
Check all of the easy things first.
Old May 2, 2008 | 06:54 PM
BLOWNBLUEZ06
Also, does it do this on the highway or do the temps begin to recover on the highway? Does it do it at idle or does it begin to recover at idle? When does it get hot? Does it ever recover from it with the engine running?
Old May 3, 2008 | 07:04 AM
Speedygonz72
Navigator
Guy, thanks for your reply on the overheating issues. I picked the car up yesterday and here are the things that have been done.
Reprogrammed the fans to come on earlier, put the stock deflector (brush guard) back on the car to direct air up into the radiator, checked the fluid to water ratio 60/40, new 160 stat, checked wiring as mentioned above (good), no collapsed hoses, flow of fluid in the overflow, new radiator cap (just in case bad cap), removed foglight bezels as mentioned above.
By doing all of this, I was able to get the temp to go from 226 degrees at 75mph to 216 degrees. But (it was 63 degrees outside last night) no reason it should be in the 200's if you ask me. Problem still not fixed. I also checked and no white smoke out the exhaust or radiator fluid in the oil, (hopefully eliminating headgasket issues) please confirm if this may or may not be an issue still. Transmission fluid is staying around 242 which is should be good.
Old May 6, 2008 | 05:15 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
242 for the trans fluid sounds really high to me
Old May 6, 2008 | 05:20 PM
atsugidad's Avatar
atsugidad
Trans is way to high. Just normal driving the Trans temp should be nearly same as Water Temp.
Old May 21, 2008 | 03:32 PM
BLOWNBLUEZ06
I pm'd Speedygonz72 to see if he found the problem. Here is his reply.
Bret, thanks for your e-mail, I did figure out what caused the issue, it ended up being the wiring on the dual fan setup of all things. one was wired correct and the other was backwards causing the heat to be circulated non-stop in the engine bay.
Old May 22, 2008 | 10:20 PM
corvette430hp's Avatar
corvette430hp
I was just wondering how the heck does the fan wires get reveresed? did someone do this by accident or was it like that from the factory?
Old May 22, 2008 | 11:28 PM
Crabr1's Avatar
Crabr1
I have a question for you,How does the fuel have anything to do with the temps,I just had my car retuned and I know somethings were changed,now I'm having a heat problem,I was told it was nothing he did,i also know he was doing things with the fuel part of the program? Let me know how it does effect so I know what I'm talking about to the tuner.
Old May 23, 2008 | 07:10 AM
AU N EGL's Avatar
AU N EGL
in addition SC just run HOT.
my first thoughts are to clean the radiators, add water wetter, seal up the radiator schauld with black duct tape. Air not flowing properly though the radiator will cause major heat increases.
Next an extractor hood to get that heat out.
Good Luck
Old May 23, 2008 | 11:02 PM
corvettejoe98's Avatar
corvettejoe98
aftermarket water pump, silicone hoses, oil cooler, cold air screens, if you want to get really hardcore get a better hood.
Old May 27, 2008 | 03:42 PM
reneeautumn
Keep in mind that the 3" tube connecting the intercoolers is blocking most of the area at the bottom which is where the air is supposed to come in. Of all the changes i made, the spal fans made the biggest difference. See my other post above re other changes i made.
To Over heating C5
