Hvac B0365 B0367
Old May 3, 2008 | 01:17 PM
indieaz's Avatar
indieaz
Default Hvac B0365 B0367
I know it's been beaten to death...but don't want to tear the dash apart prematurely
Passenger side is blowing hot regardless of settings. Initially I had no codes showing up, but after putting the A/C into auto mode and checking again I got a B0365 and B0367.
I cleared those and the right actuator began to do it's thing grinding and chugging away. 5 minutes later...it's still grinding and chugging. How long shoudl this take? I have a suspicion the door is either stuck or the gear is broken int he actuator. How likely is that?
How much are the actuators if I need a new one? If the gear is broken, is there any way to get around this without replacing it (such as with the hadlight gear flip trick).
Old May 4, 2008 | 08:30 PM
indieaz's Avatar
indieaz
Nada? Putting off this work until next weekend now. IF nothing else I guess I'll find out when i pull it apart.
