Rev Limiter
Old May 3, 2008 | 06:42 PM
C5Pat's Avatar
C5Pat
Default Rev Limiter
Just put my 3:42s in my 02 A4 and reprogramed with a Predator. everything seems fine. I hit the rev limiter while holding it in 1st, I was told that the trans would shift to 2nd on it's own, my buddy told me he heard the limiter hit and it should have shifted even though I was still in 1st??????? I don't think so. I put a 160F thermostat in, is this a good range for the fans.......Fan1 On @195..Off @ 185
Fan2 On @206.. Off @196
Thanks Guys
Old May 3, 2008 | 07:29 PM
BlackZ06's Avatar
BlackZ06
If you have the gear selecter in the "1" position the transmission will not upshift to 2nd. For an upshift to 2nd you would either need to select "2" or "3" or "D". The car can (and will) hit the rev limiter if you manually control the gears.
Old May 3, 2008 | 07:39 PM
C5Pat's Avatar
C5Pat
Thank You that's what I thought
To Rev Limiter
