I Need a engine wiring harness*@$#%&!!!
Call Gene at ...
http://www.gmpartshouse.com
He can verify the part number and help you order it.
But thanks for the link, I'm checking everywhere!
I`d look at repairing it first, you can buy a lot of connectors at rockauto.
Can you tell us more about your problem and why you think you need a new harness?
What makes you think you need a new harness ?? When you first posted the question I assumed (stupid mistake on my part) you had a good reason for putting in a whole new harness (such as an engine fire) ... but it is quite possible you don't need a whole harness ... what is the "problem" you are trying to fix ????
This may be a better direction, I can splice the plugwires in. In my experience ordering from the dealer all plugwires are white, but since the TB has 3 wires coming from it you don't know what colors to splice too! But I have the word out to some guys, C5R 427 and others, maybe someone has a junker they can just cut the wiring off of.....
I'd recommend you purchase the Service Manuals for your car. They have wiring schematics that show the gauge of a wire ... the color of the wire ... what connectors are used .... whether you rebuild the wiring, or "graft" wiring from another car ... the manuals will be invaluable.
The Service Manuals can be bought from forum vendors such as ...
or from the original publisher .....
http://www.helminc.com/helm/homepage.asp?r=
Be certain you purchase the manual for your model year ... wiring changes year to year ....
Thats the first step, no matter what you will need the manuals. It will take a while but it will have all the wiring info you need.
He means that the new connectors do not have the correct color wires on them, mostly because they are not unique to the Vette.
Don`t worry about that, the shop manuals have all the info you need. Every connector is shown with all wiring info.
Sorry, its rockauto.com They have a lot, but not all the connectors. www.ghpartshouse.com can get you anything you need.
I also had an engine fire on the pass side, oil. It scorched about an 8 inch section of the engine harness and the trans harness. The trans harness is fairly cheap, but a new engine harness was $2k. I`m trying to adapt a painless ls6 harness, but would not recommend that. Its for a hot rod, not a Vette. Too much to change, and I`m afraid now that it will cause more problems and I`ll end up buying one from GM anyway.
If it works right now, my suggestion would be:
1 Buy the manuals
2 Keep looking for a used one, look in the parts forum.
3 Save money and buy a new one if it fails before you find a used one.
I would have save a LOT of time, and I`m not done or sure it will work.
Good luck
No wonder car insurance is so freakin expensive!
The fact you walked away uninjured .... with only some wiring needing replacement .... wow ... again ... you are a lucky guy.
