Jcking Up For Oil Change
Old May 4, 2008 | 01:21 AM
Flagsdad's Avatar
Flagsdad
Default Jcking Up For Oil Change
LOOKING TO START CHANGING OIL MYSELF ,PAONT CALIPERS ETC, wHAT IS THE BEST JACK TO USE FOR THESE FUNCTIONS>
Old May 4, 2008 | 01:58 AM
motogib1's Avatar
motogib1
Below is one of the best threads I've seen for jacking the C5.
It addresses using the "prefered" jacking points which are sructural members in the front and the rear. I made my own jacking pads for these locations from 2X6 wood. You want to span the ribs on the aluminum cross members before placing jack stands to avoid potentially craking them. I drive the car onto 2X12s placed in front of Rhino ramps and drive onto the ramps. I then jack the car up using my 2x6 jacking pad. You do not require a low profile jack with this method. In the rear you can simply slide the jack with a 2x6 jacking pad placed on it and jack the rear up. Look up the tech tips portion of and it shows jacking with photos althought he did not use jack pads which I would not recommend doing. Personally I do not like jacking the car at the jacking puck locations as these are designe for a 4 -point lift. Hope this helps.
Old May 4, 2008 | 02:53 AM
thetaxman's Avatar
thetaxman
get rhino ramps and a low profile jack
Old May 4, 2008 | 03:45 AM
DeeGee's Avatar
DeeGee
Thats what I use
Old May 4, 2008 | 09:46 AM
k0ts's Avatar
k0ts
I made ramps out of 2x10s.. Then used the "old beater" jack to raise it the rest of the way..
Or you can jack under the side jacking points. I made the jacking pads out of hockey pucks..
Old May 4, 2008 | 11:02 PM
kerryt1's Avatar
kerryt1
Here's my preference:
1. 2 post lift
2. 4 post lift
3. Kwiklift
4. Mid-rise scissor lift
5. Homemade ramps + jack stands
6. Race Ramps + jack stands
Old May 5, 2008 | 11:31 AM
thetaxman's Avatar
thetaxman
race-ramps are so over priced it's not funny
300 bucks for those things
that is nuts
I paid 20 for my rhino's and a grand for my scissor lift
Old May 5, 2008 | 11:42 AM
spicytuna's Avatar
spicytuna
I never bothered with ramps myself. I just use this procedure :
http://www.z06vette.com/forums/f117/...-pucks-107706/
With my luck, I'd probably overshoot the ramps and crack my rocker panels.
Old May 5, 2008 | 10:19 PM
TEXHAWK0's Avatar
TEXHAWK0
I don't like to mess with ramps either.
I just use a low profile jack and raise whichever side or corner of the car I need to work on.
For changing oil, I just raise the left side of the car enough to remove the drain plug, then lower it back to the ground for it to drain. I can change the filter without the car even being on a jack.
To Jcking Up For Oil Change
