~ ~Brighter Blubs~ ~ ????? ~~~
Old May 4, 2008 | 01:32 AM
Vette_Fan's Avatar
Vette_Fan
Default ~ ~Brighter Blubs~ ~ ????? ~~~
Hi guys,
I'm looking to put in blackout in the front and back. But don't wana sacrifice the lighting brightness. So, anyone knows of any kinds of bulbs with are a straight swap, and would Gain me more brightness.
I wana make the Orange light in the front brighter.
Brake light bulbs brighter
Also, head lights brighter.
.... any ideas ?
Thanks..
Old May 4, 2008 | 09:55 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default too am curious
I also installed blackouts Iam curious for the rear lights to be brighter. Not sure if its possible but figured I would ask. I will check my manual to see what wattages are in there and then take a trip to the autoparts store to see what they have for higher wattages. Anyone know what the max wattage the rear bulbs circuit can handle?
Old May 4, 2008 | 06:32 PM
XtremeVette
Default ok so
I went down to autozone and found that the back up lights are 3071's and are rated at 27/6.8 watts but that if you goto 3061's they jump to 27/8.3 watts not a big jump but figured I would mention it.
Old May 5, 2008 | 04:10 PM
bighank's Avatar
bighank
Default Use 885s for thr fog lights they are a LOT brighter
Original fogs are only 37 watts. 885s are 50 watts. Can almost drive without headlights after the swap. Have run them for 2 years and haven't melted anything. Use them with the low beams all the time.
For other swap outs check the archives. Some have put hi beam lights into the low beam socket after filing down the centering plastic piece.
Haven't tried that as I went nuts after bending the small aluminium retainers and had to disassemble both lights to bend the suckers back into shape. BIGHANK
Old Aug 11, 2009 | 07:15 AM
ikipp's Avatar
ikipp
Default Brighter light from headlights
Just installed Ultras in my 98 C5. Changed both highs and lows.
Than reaimed the lights. (Really use a lot of penetrating oil and soak the plastic adjusting aiming torx screws before turning them, or they may break off.)
Was not hard to replace bulbs. I found it easier if a reached in and removed connector first and than turned the bulbs out.
Made a big, wonderful difference in lighting.
May not be as bright as HID, but is much better than stock bulbs.
Takes about 30-45 minutes.
Easy mod with good results.
Cost for all 4 bulbs on ebay was about $40.
Looking forward to putting #885s in my lower lights.
Old Aug 11, 2009 | 07:19 AM
XtremeVette
yeh I haven't found anything yet....very odd that nobody makes a brighter daytime running light amber bulb?
Old Aug 11, 2009 | 10:52 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Another very good headlight is Slyvaina SILVERSTAR Its not really brighter but a lot whiter than the standard halogen bulb.
BC
Old Aug 11, 2009 | 04:32 PM
blk6spdvert's Avatar
blk6spdvert
I am using the 9011 bulb in hi and lo beam. I like the improvement in light output. Also - HL alignment is important.
Old Aug 11, 2009 | 05:57 PM
gdev_'s Avatar
gdev_
I've had great luck with the Silverstars in the past.
Old Aug 12, 2009 | 12:29 AM
ikipp's Avatar
ikipp
Default 885
Put in 885's tonight and adjusted their aim up a bit.
Now with the Silvania Ultras and the 885 you can have some pretty good light.
Old Aug 12, 2009 | 11:37 AM
HP_Addict's Avatar
HP_Addict
What about the rear? Can you make it brighter without resorting to LEDs?
Old Aug 13, 2009 | 02:05 PM
Redshift's Avatar
Redshift
Platinum Supporting Vendor
Just be careful when doing a brighter/higher wattage bulb. Sometimes these can fry the wiring and/or melt the housings, and even more so when you do blackouts and keep more of the heat in.
To ~ ~Brighter Blubs~ ~ ????? ~~~
