WHAT IS happening???
Are you getting any codes on the DIC?
Sound like you have to check your + connection at the starter or at the battery itself.
Hot and cold can cause batterys problems.
Someone will chime in I'm sure.
Also i figured if it were the battery it would be hard to start, or I'd lose accessories as well. Everything works fine and once it decides to turn over it starts immediately.
You likely disconnected the battery per intake install instructions for the computer re-learn procedure.
Maybe you didn't get it buttoned back up quite tight enough?
If it's none of these sounds like I'll have to get into the starter... thanks!
Symtoms were exatly as you described. No crank at all, but all other accessories were fine.
Now for a true funny story from the 50's.
Chrysler gets a complaint that thier car didn't like vanilla ice cream!
The story was that without fail, when the father stopped on his way home from work and bought vanilla ice cream, the car wouldn't start when he came out. If he bought any other flavors, there was no problem.
This so intriqued Chrysler engineers that they sent someone to investigate. It turned out that indeed, when buying the vanilla, the car didn't start. After further investigation, turns out that the vanilla ice cream was at the front of the store in a convience case, while the other flavors were at the back of the store. It took less time to buy vanilla, and in the mean time, trying to restart the engine too soon after stopping caused it to vapor lock. Only waiting that extra minute eliminated that problem!
No longtubes all stock other than the filter. It's weird because I was driving home from Columbus and had been driving for little more than an hour and got gas and it started right up. So far it's intermittent at best but it definitely has to do with short drive followed by short shut off... who knows. Any way to check battery to see if it's ok? Maybe I'll just drive home(so if it doesn't start i won't be stuck) today, go inside for a few and try to restart it...
If you were waiting 2 to 3 minutes without retrying the key it could be the VATS system. The time delay before you can attempt a retry on starting the car is 3 minutes.
Bill
