Did most of you just replace the front pads witht the Raybestos Ceramics? Since most braking is with the front , and the most dust is there, is there any reason to put ceramics on the back? Trying to decide what to do.
Also any problems running the ceramics on the Eradispeeds?
You should change all pads to keep the correct bias.
I have the Rayb QS Ceramics and plan to try the EBC Green Kevlar pads next. The R QS are a bit worse than stock. EBC Greens are MUCH better than stock. The Greens may have a little dust, less than stock, more than the QS. Find them at Tire Rack.
