Engine Coolant
Old May 6, 2008 | 12:34 PM
LEN BEX's Avatar
LEN BEX
Default Engine Coolant
I Hear The Foctory Coolant Is Junk
I Need To Change Mine And I Need To Know What To Put In
Any Help From Experienced Owners Is What I Need To Hear
Old May 6, 2008 | 01:03 PM
BlackZ06's Avatar
BlackZ06
The factory coolant is "junk" ??? What pea brain told you that ????
Dexcool was specially developed by GM as a coolant and is used in all GM vehicles from Chevy trucks to Cadillac sedans.
If you want to replace the coolant, Dexcool is as good as any other product. If you want something different ... try the Prestone "green" coolant .... but you might question why even Prestone makes a Dexcool product ....
http://www.prestone.com/products/ant...freezeCoolant2
Old May 6, 2008 | 01:39 PM
SKF engineer's Avatar
SKF engineer
It's not junk, however it does react differently than the "green stuff" when mixed with contaminated or hard water from the tap. Mix it with distilled water and you should be fine, or just buy the 50/50 premix stuff.
Old May 6, 2008 | 02:58 PM
LEN BEX's Avatar
LEN BEX
A Performance Engine Builder Who Claims There Are Several Lawsuits With Claims That This Coolant Eats Aluminum.
Take It From Someone Who See's The Engines From The Inside ,all The Time.
Old May 6, 2008 | 03:02 PM
vettenuts's Avatar
vettenuts
That engine builder is full of $%it!!!!
Take it from one who has inspected aluminum internals and radiators using it. It was developed specifically for aluminum. Maybe he should read the two papers that were written to doument the problems he has seen on the internet, bottom line is "Low Coolant".
Old May 6, 2008 | 03:05 PM
SLPRC5's Avatar
SLPRC5
Old May 6, 2008 | 06:36 PM
Oldvetter's Avatar
Oldvetter
Dexcool is an excellant coolant. Early problems were due to air in system from cheap (leaking) GM gaskets. Dexcool turns muddy and thick if air is in the system.
I have 112,000 miles and 2 coolant changes on my 1998, and coolant always looked like new.
Old May 6, 2008 | 06:43 PM
BlackZ06's Avatar
BlackZ06
Your "Performanc Engine Builder" is an idiot.
There have been numerous lawsuits about Dexcool, most of which have failed to prove anything. One California court (California courts are notorious for stupid decisions .... remember OJ ????) recently "decided" that Dexcool affected certain gaskets in certain GM vehicles ...
http://www.girardgibbs.com/dexcool.html
Note the Corvette (and most other GM vehicles) are not part of the lawsuit.
Most Dexcool lawsuits have gone nowhere ....
http://www.cwcd.com/dexcool.php
because there is a huge lack of "evidence" to show that Dexcool is any worse than any other coolant, or that GM used Dexcool because they had some "evil" intention ......
Only idiots believe the Dexcool "conspiracy" theories that GM intentionally developed a coolant to screw up engines.
Old May 6, 2008 | 06:44 PM
LoneStarFRC's Avatar
LoneStarFRC
Dex-Cool and distilled water for me too. No cooling system problems at 149K miles. I do agree with keeping the system full.
Old May 7, 2008 | 12:30 PM
LEN BEX's Avatar
LEN BEX
thanks...I do believe he is full of it also!!!
Old May 7, 2008 | 12:44 PM
Bill Dearborn's Avatar
Bill Dearborn
I use Dex Cool with tap water in my 3 GM cars. GM says tap water is fine. Its nice to get 5 years of use out of a coolant. My wife's Saturn is close to its second flush and fill of DexCool. It is 9.5 years old now.
Bill
Old May 7, 2008 | 01:23 PM
Pumba's Avatar
Pumba
If your Corvette is a long-term affair, you might want to consider Evans Cooling's NPG+ waterless, lifetime coolant - www.evanscooling.com/index2.html.
I have had it in my Z06 for close to 6 years with zero problems. It never needs to be replaced.
Old May 7, 2008 | 03:28 PM
rcknusa's Avatar
rcknusa
126K, third flush just 3 weeks ago and no problems except when I don't fill it to proper level. I drain and flush every 3 years but I know it will last longer.
Old May 9, 2008 | 02:00 PM
RyanR0101's Avatar
RyanR0101
The Prestone yellow "all brand" coolant works well also. I actually called Prestone and asked what was the difference between dex cool and the yellow stuff, and they said pretty much just the color. Which should I use? Either. A GM dealership also told me they used the yellow stuff on everything.
Old May 9, 2008 | 02:10 PM
brentg454's Avatar
brentg454
Dexcool was a notorious headache for a lot of GM owners back in the 90's in gen I and II small blocks due to the incompatible (read: cheap ) gaskets that were used in the intake manifolds. All the Gen III's and gen IV's do not run coolant through the intake, so this is no longer a problem.
Old May 9, 2008 | 05:56 PM
aquaholic's Avatar
aquaholic
if you can use multimeter test the antifreeze first. put the black lead to negative at the battery and put the red lead into the coolant, you should see a .2 volt reading or less. if more than .2volts, change it.
Old May 16, 2008 | 01:05 PM
LEN BEX's Avatar
LEN BEX
what do you mean...low coolant??
this is why I started this question
my low coolant warning came on.
just low or is there trouble?
the car has 30,000 miles but it is 9 years old
I dont know if it has ever been changed but this weekend it will
thanks for the info
Len B
To Engine Coolant
